Kraton Fan surpass rocket on esc firma spektrum
Opua
Hi, I have fitted the surpass rocket fan on my spectrum esc, but now I have some doubt about the installation...the configuration like this picture, is correct?
I cant see any issues. Just make sure the fan is seated in the housing so the little power cable can reach the plug on the ESC easily. I made that mistake the first time and had to rotate the fan around for the cable to have enough room/length.
So this way the fan is ok, I mean it has to blow into the heat sink
The fan will technically work in either direction, but will be better blowing across the heat sink like you have. So yes, you have it oriented in the correct configuration (y)
