- Bozeman, MT
- Felony
- Granite
- Infraction
- Limitless
- Kraton 6s
- Nero
- Raider
- Senton 3s
- Talion
- Typhon 6s
- Vorteks
With the rapidly growing interest in drag runs so far this season, I have decided to put together an Arrmaforum Leaderboard for drag times.
Please note there are a few different classes, and they aren't all the same distance. Some are timed only, some are 132ft, and some are 188ft, based on a 1/4 mile scale.
Feel free to post your times here on this thread, and I will strive to keep it updated semi-regularly. In any posts you wish to have posted to the leaderboard, please include a header (in bold) declaring your entry so that there are fewer chances to have it buried. Similarly to the Speedrun PB list, there will be both verified and unverified runs, so feel free to submit both! To verify your run, the following must be true in an uncut video:
Last updated July 5th, 2021
- GPS must be set to Drag mode and zeroed out while the car is stationary, at the start of the run. Moving the car to the start after zeroing will void the run.
- Record your run. At the end of your run, you must be able to drive the car back to the starting position without touching it. Digging it out of a ditch will void your verification.
- Read and show the result of the run on camera. A screenshot needs to be attached to the submission as well in order to verify timing distance (or speed cutoff for the 0-40 class)
- Remove the body of the car and clearly show the battery, chassis, and drive setup. Gearing specifics are not necessary, but battery cell count, 2wd/4wd configuration, and chassis type must be clearly visible.
- 1/7 (Arrma on-road chassis, 6S max, 188ft)
- 1/10 (Arrma 3S chassis, swb or lwb, 3S max, 132ft)
- Unlimited (any chassis, any cell count, 188ft)
- Unlimited 0-40 (same rules as unlimited, tracked by time to 40mph instead of time for distance)
- 1/10 no prep (standard rules, 2wd, 2S max, 132ft) - * indicates 4wd modified to 2wd
