slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
Before we get started just be forwarded that the cheap Amazon, Aliexpress, Banggood and eBay shocks are almost always guaranteed to not be worth your time. Remember buy cheap buy twice. And it is important to have shocks that are close or as close as possible to the same dimensions as the stock shocks, if the shock body is too long you will limit the up travel of the suspension and the car will handle poorly as a result. What spring rate or fluid wt you will want to run with will depend on too many factors to list as each car will be different depending on what mods you have done or how you drive the car. An on road car will require different springs and fluid than a track car and both will require different tuning than a car that gets sent into the air 30+ feet. These are things that you yourself will have to experiment with and find what works best for you.
Some of the shocks listed below will require you to add a washer on the lower mount to keep the shock from rubbing the front driveshafts. I would try to find some washers that are about 2-3mm thick like this https://www.amainhobbies.com/team-l...208es46XjrwYJEF4WT2YpwOG0Jnaw6phoCwqQQAvD_BwE
You can make the shocks the correct length by placing nitro fuel line under the shock pistons
https://www.amazon.com/rc-fuel-line/s?k=rc+fuel+line
Video curtesy of darkeclipticheart
Arrma alloy shocks.
These are a direct bolt on just use your stock shock springs on them.
Proline Racing shocks.
These are a direct bolt on but a bit expensive compared to a lot of the other options. If you want a no fuss direct drop in this is your best bet.
Hot Racing shocks Mega and 3s models.
YOU WILL RECEIVE:
- Two 2) rear shock bodies
- Two 2) Screw-on o-ring cap eliminates the plastic seal retainer
- Two (2) aluminum spring adjusters/collars
REQUIREMENTS:
- Silicone shock oil, assembly, bleeding, and installation per Arrma recommendations
- Existing stock shock components
Arrma Mojave shocks.
The best place to source these is from Jenny's Rc. Use the Axial bushings in the upper mount to take up the space.
Arrma Kraton/Notorious/Outcast 6s shocks.
Arrma Typhon 6s shocks.
Big Bore eBay shocks.
Cheap ebay shocks these also need the previously mentioned Axial shock bushings. These shocks do not have bladders and can be a bit tricky to bleed, some users have had issues with the stock pistons having too small of holes, the rod ends are pretty poor, the shafts bend and they tend to leak.
Hot Bodies shocks.
Rather expensive and you will want to change out the springs. Also need the Axial bushings.
HPI Racing Big bore shocks.
Pretty much the same thing as the Hot Bodies shocks.(part numbers break down to be the same, except for the shock adjustment collars, they are different colors)
ZD Racing shocks.
These shocks are just okay, they will need to be shortened and the shock shafts have a tendency to break.
Tekno Racing shocks -
For Mega, 3s and 4s models you will want the shocks off the SCT410.
Team Associated RC8B3.1 shocks.
https://www.arrmaforum.com/threads/...rades-and-information.7413/page-9#post-307969
To install first you put the included insert in the ”giant hole”. Then you can insert the stock pivot ball after sanding down the ”ball” a little bit.
Hobao/Ofna Hyper SS shocks.
GPM Racing shocks.
3s models.
Arrma Aluminum Shocks.
These are a direct bolt on just use your stock shock springs.
As with the shocks for the 3s and 4s models these will need something to take up the space in the upper shock mount.
Arrma Limitless/Infraction/Felony
These will fit the front of the Vorteks.
Thanks to @Enferius being the guinea pig these springs look like they will work https://www.amazon.com/AXIAL-AX31284-Spring-40mm-6-3/dp/B012FV95PM
Arrma Mojave 6s shocks.
These shocks will only work on the rear of the Vorteks.
You will want springs pn ARA330637 these are the closest Arrma springs to the stock Vorteks spring in stiffness, they are slightly stiffer, 1.13N/mm (6.5lb/in) vs 1.06N/mm (6.05lbf/in) for the stock Vorteks rear springs, the springs are the same length 70mm.
Armma Talion 6s shocks.
These shocks will only work in the rear of the Vorteks.
Traxxas GTR Shocks.
Get VG Racing springs. https://www.vgracing.com/product/GTR_Springs.html
Proline PowerStroke shocks for the Slash.
Proline Pro Spec shocks for the Slash.
Losi Tenacity DB Pro shocks.
The rears are a little short, but you might be able to get them close in length with some long Rpm rod ends https://www.rpmrcproducts.com/shop/suspension-accessories/traxxas-long-rod-ends/
These are just like the cheap eBay shocks for the Granite listed above with all the same problems.
https://www.ebay.com/itm/283944199963?hash=item421c64a71b:g:2yoAAOSwal5YLnxH
ZD Racing Shocks.
Looking at the Q/A and reviews the springs might be on the soft side.
https://www.amazon.com/dp/B08H5C93F...NRJPKYRAGVBQ?_encoding=UTF8&tag=arrma-20&th=1
Hot Racing Shocks.
If anyone finds any other shocks that fit on these models please feel free to post them.
How to rebuild the Arrma 4x4 shocks.
Video provided by @razorrc
- Stock front shocks for the Senton, Granite, Typhon, Big Rock Crew Cab Mega and BLX 3s are 100mm eye to eye.
- Stock rear shocks for the Senton, Granite, Typhon, Big Rock Crew Cab Mega and BLX 3s are 115mm eye to eye.
- Stock front shocks for the 4s V1 models are 106mm eye to eye.
- Stock rear shocks for the 4s V1 models are 121mm eye to eye.
- Stock front shocks for the 4s V2 models are 111mm eye to eye.
- Stock rear shocks for the 4s V2 models are 133mm eye to eye.
- Stock front shocks for the Vorteks are 87mm eye to eye.
- Stock rear shocks for the Vorteks are 109mm eye to eye.
Optional shocks for the Mega, 3s and 4s models.
The following shocks are not compatible with the Arrma Vorteks 4x4 they are too long. Vorteks shocks are listed farther down in their own section.
For the upper mount when using other shocks on your Mega, 3s or 4s model use Axial part number AXA1356 https://www.amazon.com/Axial-AXA1356-Silicone-Shock-Bushing/dp/B0051W7R1MThe following shocks are not compatible with the Arrma Vorteks 4x4 they are too long. Vorteks shocks are listed farther down in their own section.
Arrma alloy shocks.
- Front -https://www.arrma-rc.com/en/product/shock-set-11mm-bore-103mm-length-500cst-oil/ARA330677.html
- Rear -https://www.arrma-rc.com/en/product/shock-set-11mm-bore-118mm-length-500cst-oil/ARA330678.html
- Front - https://www.prolineracing.com/performance-parts/power-stroke-shocks-arrma-front.asp
- Rear - https://www.prolineracing.com/performance-parts/power-stroke-shocks-arrma-rear.asp
YOU WILL RECEIVE:
REQUIREMENTS:
- Front https://hot-racing.com/?partnumber=ATF155AF08;c=1345
- Rear https://hot-racing.com/?partnumber=ATF155AR08;c=1345
- Front https://hot-racing.com/?partnumber=TFF155AF08;c=1428
- Rear https://hot-racing.com/?partnumber=TFF155AR08;c=1428
- Fronts these go in the front 108mm eye to eye.
- Mojave https://jennysrc.com/collections/ar...ks-assembled-dampers-springs-4mm-hd-ara7604v2
- Mojave EXB https://jennysrc.com/collections/ar...ks-assembled-dampers-springs-4mm-hd-ara7604v2
- Fronts these go in the rear 115mm eye to eye
- Kraton 6s socks https://jennysrc.com/collections/ar...st-assembled-dampers-springs-red-new-ar106040
- Kraton 6s EXB shocks https://jennysrc.com/collections/ar...bled-dampers-springs-4mm-2020-arrma-ara106053
- Notorious https://jennysrc.com/collections/ar...hocks-assembled-dampers-springs-red-ara8611v5
- Outcast EXB I will post these once available.
- fronts 104mm eye to eye https://jennysrc.com/collections/no...-springs-red-ara8606v5?variant=32972236685366
- rears 117mm eye to eye https://jennysrc.com/collections/no...pers-springs-ara8606v5?variant=32972252708918
- fronts are 102mm eye to eye.
- rears are 114mm eye to eye.
- https://www.ebay.com/itm/BIG-BORE-A...293293?hash=item41fb32ee6d:g:lMkAAOSwHMJYLnYG
Hot Bodies shocks.
- front 100mm eye to eye https://www.amainhobbies.com/hb-racing-112mm-big-bore-shock-set-hbs113466/p413226
- rear 112mm eye to eye https://www.amainhobbies.com/hb-racing-124mm-big-bore-shock-set-2-hbs109830/p250768
- front 97mm eye to eye - https://www.ebay.com/itm/354613862074?_trkparms=amclksrc%3DITM%26aid%3D777008%26algo%3DPERSONAL.TOPIC%26ao%3D1%26asc%3D20230811123856%26meid%3D5c9b33a0c1ce45dbaf03f8091068f0c2%26pid%3D101770%26rk%3D1%26rkt%3D1%26itm%3D354613862074%26pmt%3D1%26noa%3D1%26pg%3D4375194%26algv%3DRecentlyViewedItemsV2%26brand%3DHPI&_trksid=p4375194.c101770.m4236&_trkparms=parentrq%3Aa10bdf8618a0a8d8e9d38ad7ffff0662%7Cpageci%3Af3624e31-5504-11ee-81b3-72628a1c79f2%7Ciid%3A1%7Cvlpname%3Avlp_homepage
- rear 112mm eye to eye - https://www.ebay.com/itm/354981903919?_trkparms=amclksrc%3DITM%26aid%3D777008%26algo%3DPERSONAL.TOPIC%26ao%3D1%26asc%3D20230811123856%26meid%3D5c9b33a0c1ce45dbaf03f8091068f0c2%26pid%3D101770%26rk%3D1%26rkt%3D1%26itm%3D354981903919%26pmt%3D1%26noa%3D1%26pg%3D4375194%26algv%3DRecentlyViewedItemsV2%26brand%3DHPI&_trksid=p4375194.c101770.m4236&_trkparms=parentrq%3Aa10bdf8618a0a8d8e9d38ad7ffff0662%7Cpageci%3Af3624e31-5504-11ee-81b3-72628a1c79f2%7Ciid%3A1%7Cvlpname%3Avlp_homepage
ZD Racing shocks.
- Front: 110mm eye to eye https://www.banggood.com/2PCS-8001-...rmmds=detail-bottom-alsolike&cur_warehouse=CN
- Rear: 132mm eye to eye https://www.banggood.com/2PCS-8002-...-Rc-Car-Parts-p-1436241.html?cur_warehouse=CN
- Front 107mm eye to eye https://www.ebay.com/itm/NEW-TEKNO-...536456&hash=item21380b15c6:g:-usAAOSwNkJaFNV-
- Rear 122mm eye to eye https://www.ebay.com/itm/NEW-TEKNO-RC-SCT410-3-Shocks-Rear-TKR6016-NS28/312082133925?_trkparms=aid=333200&algo=COMP.MBE&ao=1&asc=40719&meid=299a715cf17a4671976e083a26ba3c67&pid=100008&rk=1&rkt=12&sd=142674171334&itm=312082133925&pmt=1&noa=0&pg=2047675&_trksid=p2047675.c100008.m2219
- Eye to eye measurements are currently unavailable. https://www.ebay.com/itm/ASC80935-T...067752&hash=item421652ed01:g:~IQAAOSwYyVZesaE
- Front 108mm eye to eye https://jennysrc.com/products/hobao...os=22&_sid=54fba704f&_ss=r&variant=8368405187
- Rear 125mm eye to eye https://jennysrc.com/collections/hy...88097-1-87126-90056-ofna-1?variant=8613044099
- Front total length 115mm end to end https://www.ebay.com/itm/NEW-OFNA-H...937454&hash=item21348466ea:g:vSkAAOSwk~ZaH09p
- Rear total length is 135mm end to end https://www.ebay.com/itm/NEW-OFNA-H...245274&hash=item48a51c239f:g:ex8AAOSwO7haE7RD
GPM Racing shocks.
3s models.
- Fronts 102mm eye to eye https://www.gpmparts.com/arrma-gran...damper-102mm-6pc-set-gpm-mag102f-p-13646.html
- Rears 115mm eye to eye https://www.gpmparts.com/arrma-gran...damper-115mm-6pc-set-gpm-mag115r-p-13707.html
- Fronts 107mm eye to eye https://www.gpmparts.com/arrma-krat...pers-107mm-10pc-set-gpm-maks107f-p-24427.html
- Rears 120mm eye to eye https://www.gpmparts.com/arrma-krat...pers-120mm-10pc-set-gpm-maks120r-p-24428.html
Arrma Vortex 4x4 BLX.
- Stock front shocks for the Arrma Vorteks are 87mm eye to eye.
- Stock rear shocks for the Arrma Vorteks are 109mm eye to eye.
- Rears 85mm eye to eye https://jennysrc.com/collections/ar...assembled-dampers-springs-infraction-ar109011
- Fronts 108mm eye to eye https://jennysrc.com/collections/ar...ks-assembled-dampers-springs-4mm-hd-ara7604v2
- Fronts 107mm eye to eye https://jennysrc.com/collections/ar...rings-dampers-ar106048?variant=20329031565366
Traxxas GTR Shocks.
- Fronts 87mm eye to eye https://www.ebay.com/itm/274394584293?hash=item3fe33114e5:g:KS0AAOSwSWde4oZc
- Rears 103mm eye to eye https://www.ebay.com/itm/192771284109?epid=1203434569&hash=item2ce2105c8d:g:ksYAAOSwgYBggyYs
- Fronts 88mm eye to eye https://www.prolineracing.com/performance-parts/power-stroke-shocks-front.asp
- Rears 102mm eye to eye https://www.prolineracing.com/performance-parts/power-stroke-shocks-rear.asp
- Fronts 88mm eye to eye https://www.prolineracing.com/performance-parts/pre-assembled-pro-spec-shocks-front.asp
- Rears 100mm eye to eye https://www.prolineracing.com/performance-parts/pre-assembled-pro-spec-shocks-rear.asp
- Fronts 85mm eye to eye https://jennysrc.com/collections/lo...-desert-buggy-los03027?variant=33054087774262
- Rears 100mm eye to eye https://jennysrc.com/collections/lo...-desert-buggy-los03027?variant=33054116446262
ZD Racing Shocks.
- Rear 105mm eye to eye
Hot Racing Shocks.
- Fronts 90mm eye to eye https://hot-racing.com/?partnumber=TD90X06;c=430
- Rear 105mm eye to eye http://www.hot-racing.com/index.cgi?partnumber=TD105X06;c=901
