- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
This thread will serve as the Arrma forum 2022
4s speed run challenge for 1/8 and 1/7 cars (not the Arrma 3s or 4s line specifically, but a challenge for running 4s voltage)
Rules:
- Have fun and enjoy the journey
- Be safe and considers others' safety!
- Help each other improve
- Must be 4s voltage (any number of batteries parallel as long as it stays 4s LiPo max voltage) (4.2v * 4 = 16.8v max voltage post run) (overcharging is allowed)
- Any motor (assuming we are ok with dual motors should someone want to run that, but will be split off onto a separate list)
- Any ESC (come on it's always the XLX2 )
- Any tires (Rubber or foam)
- Chassis any 1/8 or 1/7 ("1/10" cars like Slash 4x4 that are truly by size/measurement a 1/8 scale are allowed)
- (NO 1/10 scale small touring cars like 4tec, serpent, Tamiya etc)
- Standard rules for showing GPS that we normally do.
- In your video show the batteries are 4s (5 wires) and if running parallel clearly show the connection going to the ESC.
- Do not have to return the car, but crashes disqualify the run
****Post your video link in this thread and I'll edit the original post with a spreadsheet of standings a few times per week. Also note the car so I can keep up with the list. (I'll track up to 2 of your cars, but you must tell me the model of car in your thread post)****
(Optional if you want to share what motor, batteries, and gearing you are running. I am totally fine with you keeping that secret if you would like)
Rules:
Dual Motor Cars | ||||||||
Ranking | Member | Speed in MPH | Cells | Car | Motor | KV | Battery | Video confirmed |
1 | VWturboWolf | 170 | 4s | Limitless (1/7) | Dual motor TP | 1 per side | Yes |
Single Motor Cars | ||||||||
1 | VWturboWolf | 163 | 4s | Vendetta | TP4050 | 1p | Yes | |
2 | VWturboWolf | 161 | 4s | VTE2 | TP | 1p | Yes | |
3 | Slow RC Mike | 160 | 4s | VTE (1/8) | Castle 1515 v2 | 2200 | 2p | Yes |
4 | phildogg | 152 | 4s | Slash 4x4 (/18) | Castle 1721 | 2400 | 2p | Yes |
5 | MP-RC | 149 | 4s | VTE (1/8) | TP | 2p | Yes | |
6 | LibertyMKiii | 146 | 4s | VTE2 | TP4070cm | 2p | Yes | |
7 | K-bash | 145 | 4s | Vendetta | TP | 2P | Yes | |
8 | K-bash | 140 | 4s | Typhon 6s GT (1/8) | Castle | 1p | Yes | |
9 | Chris Adams | 138 | 4s | Typhon stretched | TP | 1p | Yes | |
10 | Chris Adams | 137 | 4s | Infraction GT (1/7) | Castle 1721 | 2400 | 1p | Yes |
11 | Edough13 | 132 | 4s | Limitless GT | Castle | 2p | Yes | |
12 | Diem Turner | 131 | 4s | Infraction GT (1/7) | Castle 1721 | 2400 | 2p | Yes |
13 | RedondoBeachRC | 123 | 4s | Limitless V2 (1/7) | Castle 1721 | 2400 | 2p | No |
14 | Edough13 | 122 | 4s | Stretched Typhon (1/8+) | 2p | Yes | ||
15 | real_name_hidden | 104 | 4s | Limitless (1/7) | TP | 1p | No | |
16 | RedondoBeachRC | 101 | 4s | Infraction (stock body) | TP4080 | 2700 | 1p | No |
Hi-Voltage | ||||||||
1 | Slow RC Mike | 161 | 4s | VTE (1/8) | 1721 | 4.23 p/cell post run | Yes |
