Kraton All Arrma 3s models loaded with AVC
Mike-NLD
Breda - The Netherlands
  1. Outcast 6s
  2. Typhon 6s
Hi all,
Just an heads up here..
If you want to run AVC or similar in your 3s rig, make sure you upgrade your servo to a digital one!
The stock ADS-7m is an analog servo, and cant handle the AVC input..
It gets way to hot in prob your first or second pack you run it with AVC..
Smoke comes out.. And its done..
I just bought an arrma senton 3s blx yesterday and which digital servo works with this AVC system? I also bought DumboRC X6 with gyro, is it the same thing?
I also did the mods since I wanted the AVC system. I learned the hard way about a few things. Here is my final set up including a few tips.
  • Spektrum RC DX5C 5-Channel DSMR Surface Radio
  • SR6100AT Receiver
  • DS3225 25KG Coreless Digital RC Servo
I was originally told by a hobby shop person that I would be able to run the stock analog-servo (Not True). I quickly discovered that the servo saver that came with the digital servo would not work. I ended up using the stock saver and arm. There are other options but I want it to simply fit and maintain the geometry. I then discovered that the system needed to be reset and calibrated for the ESC to work correctly.
I'm very happy with the outcome and kept making upgrades. I'm new to the hobby and have only been doing it for less than a month. I'm hooked and now I'm designing and prototyping ramps. I've also figured out how to make a lap timer for under $150.
I personally purchased the Spektrum RC DX5C 5-Channel DSMR Surface Radio since it was also a Spectrum product and bundled with the SR6100AT Receiver. See my post above.
Bundle:
https://www.amainhobbies.com/spektr...ce-radio-w-sr6100at-receiver-spm5120/p1049208
Spektrum AVC:
https://www.spektrumrc.com/Technology/AVC.aspx
  • SR6100AT Receiver
Bundle:
Spektrum AVC:
I think I will use the gyro that came with DumboRC and upgrade the servo later.
  • SR6100AT Receiver
Bundle:
Spektrum AVC:
Hi,
I bought the same receiver as you ( SR6100AT Receiver ) and I have a Talion v4.
The receiver does not fit into the radio box (RADIO BOX SET #AR320422) :-/
Did you had the same issue? I am searching if any other radio box could fix my problem....
Ideally, I prefer to not cut the radio box to keep it waterproof..
Any ideas?
Thanks!!
Hi,
Any ideas?
Thanks!!
Odd, it fit but needed to be placed perpendicular. Let me look up the dimensions to your box. And no, I did not have to cut the box. Sit tight, BRB.
#AR320422
SPECIFICATIONS
Length: 1.8 (46mm)
Width: 1.6 (42.1mm)
Height: 1.4 (36.4mm)
Senton 3s
https://www.arrma-rc.com/part/AR320400
SPECIFICATIONS
Box Dimensions:
2.7 x 2.2 x 1.4 (70 x 56.8 x 35mm)
#AR320422
SPECIFICATIONS
Length: 1.8 (46mm)
Width: 1.6 (42.1mm)
Senton 3s
SPECIFICATIONS
Box Dimensions:
Not good news! Looks like the box is slightly smaller. The Senton box is 2.7x2.2, making it a rectangle shape and allowing the SR6100AT Receiver to fit.
Will the AR320400 box fit in your chassis?
Senton 3s box
Talion box
Possible solution:
https://www.spektrumrc.com/Products/Default.aspx?ProdId=SPMSRS4210
Length:1.43 in (36.3mm)
Width:0.96 in (24.4mm)
Height:0.51 in (13.0mm)
Thanks for your quick answer!
I will check if the anchor screw of this box can fit.
My current radio box only have 1 screw for the chassis and the 2 arm attached to my battery case.
(y)
Hi,
Any ideas?
Thanks!!
I’d buy a different rx im on my third one in kraton 8s they do not last
:D WOW! A new EXtreme Basher (EXB) radio box just appears for my Talion in pre-order coming out this july.
Dimension seems to fit now!!
#AR320604
Maximum Internal Dimensions (L x W x H): 52mm x 36mm x 33mm
https://www.arrma-rc.com/part/ARA320604/TALION/ALL/ALL/ALL#xref
-> Pre-Order from Horizonhobby for July 2020 :cool:
https://www.horizonhobby.com/product/radio-box-set/ARA320604.html
SR6100AT 6 Channel AVC/Telemetry Surface Receiver
Dimensions (L x W x H): 42.4mm x 23.9mm x 15.1mm
https://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMSR6100AT
I should go buy lottery tickets!! ?
Txs for your helps!
i want to put avc on my big rock so being new to this what do you suggest? I was looking at a dx3
