- Kraton 6s
- Kraton EXB
Anyone else have one of these does yours leak diff lube out the grub screw mine does how did you stop it I'm about to use Teflon tape on the ground screw or pipe dope
And just the grub screw is tight and yes, there is loctite on itAnyone else have one of these does yours leak diff lube out the grub screw mine does how did you stop it I'm about to use Teflon tape on the ground screw or pipe dope
