Probably a bit late to the party here lol but great info! Is there something similar for diff oil as the measurements seem to generally be much higher. Specifically 3000, 5000, 7000 and 10000 WT to CST?
Does anyone know how cps correlates to cst? I want to make my mojave a bit stiffer but on my oil bottles it only says how thick it is in cps. Is 750cps thicker than 550 cst?
I think they are the same. ✌?So, like you i have CPS rather than CST, along with a WT. I bought Absima silicone oils
Shock oils:
200cps = 19wt
350cps = 30wt
Diff oils:
3000cps = 185wt
30000cps = 1290wt
50000cps = 1985wt
Are CPS and CST the same or is CPS a European rating and CST American?
Very confused (in the UK) ...
Kraton uses 1000cstA couple people have asked how the cSt oil weight converts to wt values that are found on many shock oil bottles. Below are the shock wt values converted to cSt as well as the conversion of Arrma-RC models for easy reference.
Shock oil sets:
Team Losi Shock Oil 6Pk - 20, 25, 30, 35, 40, 45
Team Losi Shock Oil 6Pk - 50, 60, 70, 80, 90, 100
WT to CST Silicone Oil Conversion Chart
10wt = 100cst
15wt = 150cst
20wt = 200cst
25wt = 275cst
30wt = 350cst
35wt = 425cst
40wt = 500cst
45wt = 575cst
50wt = 650cst
55wt = 725cst
60wt = 800cst
70wt = 900cst
80wt = 1000cst
Arrma Granite shocks use 350cSt (or 30wt) oil.
Arrma Kraton shocks use 550cSt (or roughly 43wt) oil.
Arrma Nero shocks use 1000cSt (or 80wt) oil.
Thanks @WoodiE for the info on shock oil, by chance is there one floating in the forums on Diff oil?A couple people have asked how the cSt oil weight converts to wt values that are found on many shock oil bottles. Below are the shock wt values converted to cSt as well as the conversion of Arrma-RC models for easy reference.
Shock oil sets:
10wt = 100cst
15wt = 150cst
20wt = 200cst
25wt = 275cst
30wt = 350cst
35wt = 425cst
40wt = 500cst
45wt = 575cst
50wt = 650cst
55wt = 725cst
60wt = 800cst
70wt = 900cst
80wt = 1000cst
Do you think 50wt is too much for a beefcake typhon. Has m2c chassis and is truggified so has some extra weight there. I’m referring to shocksA couple people have asked how the cSt oil weight converts to wt values that are found on many shock oil bottles. Below are the shock wt values converted to cSt as well as the conversion of Arrma-RC models for easy reference.
Shock oil sets:
10wt = 100cst
15wt = 150cst
20wt = 200cst
25wt = 275cst
30wt = 350cst
35wt = 425cst
40wt = 500cst
45wt = 575cst
50wt = 650cst
55wt = 725cst
60wt = 800cst
70wt = 900cst
80wt = 1000cst
Thank you very much!!A couple people have asked how the cSt oil weight converts to wt values that are found on many shock oil bottles. Below are the shock wt values converted to cSt as well as the conversion of Arrma-RC models for easy reference.
Shock oil sets:
10wt = 100cst
15wt = 150cst
20wt = 200cst
25wt = 275cst
30wt = 350cst
35wt = 425cst
40wt = 500cst
45wt = 575cst
50wt = 650cst
55wt = 725cst
60wt = 800cst
70wt = 900cst
80wt = 1000cst
Thank you for this.A couple people have asked how the cSt oil weight converts to wt values that are found on many shock oil bottles. Below are the shock wt values converted to cSt as well as the conversion of Arrma-RC models for easy reference.
Shock oil sets:
10wt = 100cst
15wt = 150cst
20wt = 200cst
25wt = 275cst
30wt = 350cst
35wt = 425cst
40wt = 500cst
45wt = 575cst
50wt = 650cst
55wt = 725cst
60wt = 800cst
70wt = 900cst
80wt = 1000cst
