My tire weight list
olds97_lss
Bash Break Repeat!
Dekalb, IL
  1. Kraton EXB
  2. Outcast 6s
Just a running list of the tires I've either had myself or got weights from others for. If you have the weight of something not on the list, let me know and I'll update it.
The ones listed as mine were weighed on the rim on a USPS scale that only does oz. I converted to grams and lbs.
Tires: 51BrandTireBeltedRim/IDOffsetODOzGramslbsMine
TireArrmaDboots Ragnarok AR550053N2.806.138174.010.38N
TireArrmadBoots Hoons 43/100-2.9Y2.903.916111.000.24N
TireArrmadBoots Hoons 53/107-2.9Y2.906.596187.000.41N
TireArrmaBackflipsN3.81/417212.500354.370.78Y
TireArrmaBackflips LPN3.81/41549.875279.950.62N
TireArrmaBackflips LP on Traxxas 8671N3.81/215410.000283.500.63N
TireArrmaCopperhead 2N3.81/411.625329.560.73N
TireArrmadBoots FIRETEAMN3.1/3.8?16912.980367.980.81N
TireArrmaKatar (talion v2/3 stock)N3.81/41457.160202.980.45N
TireArrmaMinokawa LP (Kraton 4S)N3.81/49.350265.070.58N
TireArrmaMinokawa Mt (Kraton v3)N3.81/410.500297.670.66Y
TireArrma PincerN3.81/411.640329.990.73N
TireDuratraxSix Pack MT - DTXC5604 Y2.81/28.395238.000.52N
TireDuratraxSix Pack X - DTXC5502 (XMaxx)Y4.3?~8"27.267773.011.70N
TireDuratraxx-cons truggyN41/21449.700275.000.61N
TireGRPGRP GTX01-S5Y3.89983.06987.000.19N
TireGRPT01 REVO (S3 compound) beltedY983.07287.090.19N
TireJetKoSuper Sonics MT StreetY3.81/215.556441.000.97N
TireLouise RCST-ViperN3.8016.150457.841.01N
TireLouise RCT-ApolloN3.808.750248.060.55N
TireLouise RCt-rockN3.809.060256.850.57N
TireMethod RCTerraform All-Terrain Belted 1/8th Monster Truck Tires on Array 17mm Hex Wheels Y82/17214.674416.000.92N
TirePowerhobbyScorpion beltedY4.51/45.813.000368.540.81N
TirePro-lineBadland MX 2.8N2.87.619215.990.48N
TirePro-lineMX28 HP beltedY2.85.026.349180.000.40N
TirePro-lineTrencher 17mmN2.87.100201.280.44Y
TirePro-lineTrencher 17mm beltedY2.81/28.466240.010.53N
TirePro-lineBadland 17mm - hub insertsN3.809.200260.820.58N
TirePro-lineBadland 17mm - standard hubN3.808.600243.810.54N
TirePro-lineMasher N3.8013.157372.990.82N
TirePro-lineMX38N3.8016.089456.121.01N
TirePro-lineMX38 beltedY3.8014.740417.870.92N
TirePro-lineRoadRage 1177 desperado 17mmN3.81/29.375265.780.59N
TirePro-lineShockwaveN3.809.900280.660.62N
TirePro-lineSlingshotN3.809.277263.000.58N
TirePro-lineTrencherN3.8013.400379.880.84Y
TirePro-lineTrencher LP - hub insertsN3.809.800277.830.61N
TirePro-lineTrencher LP-plastic hubs wrappedN3.81/210.000283.500.63N
TirePro-lineTrencher XN3.81/213.651387.000.85N
TirePro-lineTrencher X beltedY3.81/216.967481.011.06N
TireRCStation-Amazon17mm .5" offset MT (maybe more offset)N3.81/29.400266.490.59Y
TireRedcatKaijuN?1/25.8"10.120286.900.63N
TireSP RacingSP-GT-50 (50 shore)N1/2982.58873.370.16N
TireThunder TigerMT4 G3 17mm keyed hexN3.81/212.500354.370.78Y
TireTraxxasMaxx 4S 17mmN2.88.200232.470.51N
TireTraxxasSledgehammer 2.8 (12mm hex)N2.88.200232.470.51N
TireTraxxasSledgehammer 2.8 (17mm hex)
front/rear ID's differ
N2.89.800277.830.61Y
TireTraxxasChevron 3.8 on GeodesN3.81/2"10.000283.500.63Y
TireTraxxasMaxx AllTerrainN3.8011.500326.020.72Y
TireTraxxasTalons v1N3.809.100257.980.57Y
TireTraxxasTalons v2 EXTN3.81/2"13.900394.060.87Y
This is great!
I'm thinking it would be beneficial to add 2 columns to the table.
Tire Diameter
Belted (Y or N)
Ugh... that sounds like work. lol!
Updated, but I don't have the OD's. I'll look some up and measure mine after work, or some time soon.
Are the Katars V3/V4 for the Talion iirc the V1 and V2 had the truggy style tires.
If it helps I just weighed my speed run tyres for you @olds97_lss to add to your list.
"GRP" tyre, model "T01 REVO" (S3 compound), Belted, 98mm/3.86" (rim & tyre total), 3.072oz/87.11grams/0.19lbs
"SP Racing" tyre, model "SP-GT-50" (50 shore), Not belted, 98mm/3.86" (rim & tyre total), 2.588oz/73.38grams/0.16lbs
(y)
Tire/TruckBrandTireBeltedRim/IDOffsetODOzGramslbsMine
TireArrmaBackflipsN3.8012.500354.370.78Y
TireArrmaBackflips LPN3.809.875279.950.62N
TireArrmaKatar (talion v2/3 stock)N3.81/2"7.160202.980.45N
TireArrmaMinokawa LP (Kraton 4S)N3.81/2"9.350265.070.58N
TireArrmaMinokawa Mt (Kraton v3)N3.81/2"10.500297.670.66Y
TireArrmaPincerN3.8011.640329.990.73N
TirePro-lineBadland 17mmN2.808.500240.970.53N
TirePro-lineMasherN3.8013.157372.990.82N
TirePro-lineMX38N3.8014.600413.900.91N
TirePro-lineRoad Rage 1177 desperado 17mmN3.81/2"9.375265.780.59N
TirePro-lineTrencher 17mmN2.81/2"7.100201.280.44Y
TirePro-lineTrencher 17mmY2.81/2"8.466240.010.53N
TirePro-lineTrencher XN3.81/2"13.651387.000.85N
TirePro-lineTrencher XY3.81/2"16.967481.011.06N
TireThunder TigerMT4 G3 17mm keyed hexN3.81/2"12.500354.370.78Y
TireTraxxasTalons v2 EXTN3.81/2"14.200402.560.89N
Nicely done @olds97_lss! Took a fair bit of time to compile the list. I think @WoodiE should turn this post into a stickie. ??
well done.
Got one more for you if you want to add it to the chart.
Powerhobby Scorpion belted tires, race compound.
Advertised specs: 147mm od, 81mm wide, 13.3oz, 1/4" offset
Written on sidewall: 5.8" od, 3.2" wide, 4.5" rim diameter
Measured weight 12.991oz average for my 4, with none being more than 0.03 oz out from the average.
Sticky feel to the compound. Have not driven them yet. I got them for my Nephew to do dirt road speed runs on his Kraton, hopefully this weekend. May give them a try on my Talion tomorrow if I get a chance.
@olds97_lss if you want some help with the ODs I looked a few up on Arrma's site for you:
Backflip 172mm
Copperhead2 169mm
Backflip LP 154mm
Katar (Talion v4) 145mm
Updated. Didn't have a weight for the copperhead 2's, so didn't add that.
Not sure why, the forum kind of fought me on pasting the table this time. I had to copy it out of google sheets, then put it in openoffice calc (I don't use excel anymore), then copy again and put it here.
I noticed you didn't add the tyres I checked for you, ...GRP's and SP Racing foams.
Are you not adding on-road tyres then or just missed my post?
Just curious. ;)
Missed it, then had to think if I cared... I don't since I never would run them, but others might, so I added them.
Updated the list. They look like they are 1/2" offset, but don't know the OD. Couldn't find them on arrma's site, searching for copperhead appears to just come up with the v1's.
What should I upgrade when using a heavier set of wheels on the Kraton 6s (i.e. > 430 g)?
