Mega 4x4 How-To videos
WoodiE
Kind of good admin
Community Leader
Lexington, KY
  2. Mojave EXB
Arrma-RC has several great videos on how to maintain your Arrma MEGA 4x4 RC and I wanted to share them here in one easy to find place.
If you find any others related to the MEGA 4x4 RC's please post them here as well.
Removing Electronics Module
Removing Power Module
Remove the Diffs
Shock Access
Slipped Adjustment
I have a shock that extends out more then the other 3 and last time out car seemed to have a wobble to it
Remove the Diffs
Shock Access
Slipped Adjustment
Great tutorials! i'm going to rebuild the diff's in my BRCC. I'm going to probably replace the gaskets. Any suggestions about where to buy them? besides installing sealed bearings, is there anything else I should replace? Thanks.
Anyone know the name of the tool he's using
A couple of years too late, but it's a Hudy 120mm long 2mm Hex Driver.
A little late again to contribute from my side, but I guess someone else might benefit from this in the future:
Here are Arrma diff gaskets that I use:
https://www.hobbytown.com/arrma-3s-blx-differential-gasket-2-ara310875/p773831
Other than diff gaskets and bearings, upgrade your input gear with Arrma HD ones, and use the right diff oils, 100K front and 30K back as jondilly1974 had recommended to me a lil while back.
CHANGE YOUR MOTOR BEARINGS ASAP. I learned the hard way and lost a motor 2 weeks in.
Does anyone have a video on how to assemble the slipper clutch using hot racing's spur and 4s aluminum plates?
Hey all. My son bought a Senton 550 Mega and needed to repair the slipper clutch on it. The store he bought the car from sold him the wrong parts and we've been having a difficult time trying to find them. I was wondering if anyone knew a place in Ontario Canada, or Canada in general, we could get the parts or a full slipper clutch assembly. I've tried to get them from the shop that pops up on the exploded view by clicking the links here:
https://www.arrma-rc.com/interactive-exploded-view/ARA102715T1
But most of the parts are on back order. Any help is greatly appreciated.
Thanks in advance.
Servo install (including Kimborough #124 servo saver mod) instructions.
