Kraton Kraton 4s mph guesses? Stock 2400kv on 8s..?!
neighborhater383ci
Albany Oregon
  1. Kraton 4s
  2. Senton 3s
she did 78 earlier today with a 20t pinion 57t spur on 8s and body at stock height. Went ahead and used a older style front shock tower because it sits lower down, used a granite front body post cut down to make the body sit on the shock tower as low as possible, made a air dam to hopefully help with drag along with taking the wing off and rear mud guards. Odd idea but I put the mudguards up under the front control arms in a way that blocks air from going up into the wheel well. Yes the motor got hot, not worried as I have a 2050kv to replace if/when she lets go
So you've just done aero/body changes and still running the same pinion/spur?
Maybe a couple MPH more unless you packs were low last time
That and I’m gonna give it more run up. I figure it should be a noticeable change based on how not aerodynamic it is in stock form, wondering what the biggest pinion I can run is with the center diff still intact
