- Granite
I think there is a new option with the release of the Mojave 4s. The Mojave 4s provides a driveshaft upgrade, with 17mm hexes, and extremely beefy axles. Furthermore, I think it can be done without modifying any parts. However, you will have to buy a number or parts.
The Mojave 4s arms/hubs/steering blocks give you a wider stance than a Granite/Vorteks/Senton. **EDIT - According to the post below, the stance is about the same as a Typhon/Big Rock.
***** Big Edit
Kraton/Outcast/Mojave hubs will NOT fit on 3s arms. So you can’t use Granite/Vorteks/Typhon/Big Rock arms with the new driveshafts. You have to use Mojave or Kraton/Outcast arms
To use the new 4s driveshafts you also have to get 4s arms, axles, c-hubs, rear hubs, hexes/nuts/pins, and steering blocks. If you use Mojave arms and driveshafts, you have to use Mojave steering blocks. If you use Kraton/Outcast arms you need the Keaton/Outcast steering blocks. The Mojave also has a different steering rack.
So, to upgrade to the new 4s driveshafts
- Mojave or Kraton/Outcast arms
- Mojave or Kraton/Outcast driveshafts
- Mojave or Kraton/outcast turnbuckles/rod ends
- Mojave or Kraton/Outcast steering blocks
- 4s wheel axles
- 4s 17mm hexes
- 4s hex nuts
- 4s hex pins
- 4s C-hubs
I’m currently building a swb with Mojave arms/steering blocks/driveshafts/steering rack. I have not driven it yet, but I can tell you the 4s parts feel like such higher quality than 3s parts. The arms, axles and turnbuckles are so beefy. The wheel bearings are huge. The fit feels much tighter. This may change after I run it, but right now, there is no wobble!
***** Big Edit
- 4s wheel axles
- 4s 17mm hexes
- 4s hex nuts
- 4s hex pins
- 4s C-hubs
