I have a outcast 8s bxl
Mattb2580
New Member
For some reason, it does not seem very fast and now. When I plug a battery into it, it will be 6 times have a short pause. Then a seventh beep. I don't know if it is on a wrong setting or what, but it used to be more. And how do I get it to go back? And how do I get my power back?It doesn't even have enough power to pop a wheelie anymore and yes it has fresh batterys
Try Clean & inspect ur drivetrain to see any binding occur. I was in ur case ago after i load my BRCC with heavy rigs. Especially if u are using the metal driveshaft easy to rusted if careless maintenance. Try do lower pinion gear teeth, tighten slipper clutch more & change the diffential fluid to thicker solve my undo wheelie problems.
