ajdragon
- Raider
Hi
I saw where a few people are having problems removing the tranny in the Arrma 1/10 scale cars.
Here is the way I remove my Tranny.
Step 1: Disconnect your motor wires.
Step 2: Remove the screw the yellow arrow is pointing to, and then unscrew the two screws the blue arrows are pointing to half way out.
Step 3: Remove these two screws.
Step 4: Remove these two screws.
Step 5: Remove the bar the yellow arrow points too, then pull the two plastic pieces apart the green arrows are pointing too, and then remove the rear skid plate "blue arrow"
Step 6: Remove this pocket screw and the one on the other side.
Step 7: Remove this shock screw on both sides and then swing the shocks upwards.
Step 8: With the shocks out of the way you can now remove these two screws and the two on the other side.
Step 9: Disconnect the tie rods.
Step 10: Grab the tranny and rotate it like this and it will pop right out.
