Granite Granite blx 2wd
Hey I own a Granite blx 2wd, would love to see pictures of other units. Don't seem to see too many of them anymore.
Wow, I didn't realize they made 2WD BLX units. I'm curious to see the them as well.
Looks awesome! Is that the stock servo in there still? I had to change mine after the first few runs, still having issues keeping a tough servo in it. Think I will get myself that tbone bumper aswell.
Anyone know if any other metal diffs will fit the blx 2wds?? Looking at maybe buying a cheap roller I seen and going 4s, maybe the ECX metal Diffs fit??? Anyone?
I read a while ago somewhere that the HPI Blitz diff can be used as replacement. This was like 4 years ago.
The HPI Blitz ball diff from MIP works, you just need a few shims to set it right in the transmission housing. I did that on my Fury, which, for those that don't know, the 2WD Granite BLX, Raider XL, Fury, and 2WD Mojave all share the same chassis and components. Now i just need to find some current CVD's and hubs that will work in it, so i can start running it again.
Any luck finding CVDs and hubs that work?
Not yet. I actually got lucky though and found the 83MM hardened dog bones, and aluminum rear hubs on eBay, and i haven't had an issue with it since, except for bending one dog bone, but i bought 6 sets just to have.
Do you mind sharing what manufacturer and models of those aluminum pieces are? Also the full metal trans gears parts, or was that a fully assembled part by itself?
These are the rear hubs: https://www.ebay.com/itm/2947232322...Zv/PMLpcYU29xVKrA1CURFJFQeUk|tkp:BFBMxq_f3oNg
These are the dogbones: https://www.ebay.com/itm/1328618307...wlV+PY0xQu8yCe8AS6jJ8pCxmPaJ|tkp:BFBM3LLj3oNg
This is the diff i used: https://www.ebay.com/itm/283868890656?hash=item4217e78620:g:cNMAAOSw9jdescAV
These are what i used to shim the diff: https://www.ebay.com/itm/175138034145?hash=item28c70a51e1:g:ghwAAOSwO1Fh-TBy
If you do a search on eBay, you can find almost every part, except for the original diff, for the Fury and Raider.
If you do a little modifying to the rear arms, you can also use the parts from the Losi 22s SCT, such as lower rear arms, hubs, and axles.
