Diem Turner
Yes...I have a Premium Member
Rig of the Month Winner
The Arrma 6S line doesn't have a transmission per se as the pinion meshes directly with the center diff/spool which in turn connects to the diffs via drive shafts. Any gear or speed calculator should have a slot for diff ratio (Limitless/Infraction v1 both had 3.21 diffs, the v2 of both have the 2.8 diffs) and some calculators have a slot for transmission ratio. For any of these cars you would just put a 1 for the transmission ratio (i.e. no effect on the calculation).Where did the 48 come from? The V2 Should’ve came with a 39. I have a question for those who know (V2 Limitless) what number goes in the transmission portion of the gear calculator 3.30 2.80 I’m a little confused as to what to put in there sometimes.
