- Catskills, New York
- Kraton EXB
- Mojave EXB
- Typhon 3s
- Typhon 6s
- Voltage
The thread formally known as An Idiots Guide to a Truggy 6S Build and some Resulting Carnage
So im not really sure which direction is best.
More like a Kraton with its 3.8x6.5" wheels or more like a Talion with its smaller 2.2x5.7" wheels? Compared to the Typhon 6S's with its stock 1.7x4.6" wheels.
I like the Bandito C2 at 1.8x4.2" wheels for the Typhon 3S. Nice amount of wheel spin and balance. I'll do the belted ones next time, over 45 they get funky. And they don't seem to last all that long.
I decided to start off with Kraton Wheel Hubs, spindles and hex hubs to properly accommodate some larger 2.8x5.4" offset tires. I have 15mm extended hubs too if I need them but i likely wont for 2.8's. I got them to try out some larger 3.8x6.5 wheels at some point without having to change the arms and shocks to see if I like it first. Although I already have the Kraton Driveshafts so...
The way I see it, the wheel height difference with its stock 16T pinion and 50t spur will make it fast! Its only a half a pound heavier with the bigger belted tires and hubs at around 7.92 lbs (3.59kg) compared to a 10.67 lb (4.85kg) Kraton with a 12t/50t and 3.8x6.5" wheels. The Typhon Braton Should hit a 100mph with Lipo 6S 100+C on pavement. I have the Duratrax Bandito MT Belt 2.8's for that try. And a set of Duratrax Sixpack MT Belt 2.8's for the fields. Its gonna need a fan but its cool where I am year round mostly, never gets that hot for that long. So we'll see when thats needed. LOL
The somewhat wider stance and tire patch should give the Typhon 6S the traction to hit and maintain speed and stability. Although its a bit short :-/
Thats how the Typhon 3S was able to go so fast. Better traction! Those stock tires just loose grip at all speeds slowing the car down and its gets unstable which also slows the car down.
Im concerned about pulling wheelies with the Truggy to easily! Its a waste of energy although lots of fun. We'll get to that with diff oils. I have 30k, 60k and 200k cps from Ultimate Racing to start off with.
Previous upgrade prelude for the Typhon 6S BLX V5 includes a Flysky FS GT5 with BS6 Gyro Receiver, 35KG 7.4v High Torque Servo with an Aluminum Steering Servo Mount. The stock ones are so bad! FastEddy Bearings (I spun 2 stock arrma ones in the first week!), RPM and Arrma EXB bumpers front and rear (I don't like the EXB bumper so much) but waiting for TBR to have them for the 6S BLX's. I have (2) HOOVO 6S LiPos at 8000mAh 100C for it. And some 3S 100C 8000mAh Lipos as well as some 2S's at 80C.
I'll get a lighter weight lower mAh battery for high speed runs when I need it. The good ones are expensive!
The 8000mAh's are heavy but boy do they last and give up power!
I'll post photos with descriptions as it comes along. Take advice and show results.
The Truggy below is waiting for parts, its NOT road ready or adjusted/tuned. This was for sizing up.
The Typhon 6S is wearing Duratrax Bandito MT Belt 2.8s at 2.8" x 5.3" (stock is 1.7" x 4.6")
The Typhon 3S is running and wearing Duratrax Bandito Buggy Tire C2s at 1.8" x 4.2" (stock is 1.7" x 4.6")
Typhon 3S (just because she likes her new sneakers)
Some of the notes I refer to:
Kraton 6S 60 mph+ 1/8
- FIRMA 4074 2050KV
- BLX185 ESC 150A
- Stock Fitted Pinion: 12T, 1.0m pitch
- Stock Fitted Spur: 50T, 1.0m pitch
- Dif Crown Gear: 43t 0.9m
- Dif pinion Gear: 10t 0.9m
- internal Gear Ratio: 4.3
- Final Drive Ratio: 17.92:1
- Tire overall diameter: 6.5" (169mm), , Width: 3.8" (97mm), 3.28lbs/quad 1.49kg, DBoots® COPPERHEAD2 3.8
- Wheelbase: 14.84 in (377mm)
- Width F/R: 18.15" (461mm)
- Weight Stock: 10.67 lbs (4.85kg) - 3.28 lbs (1.49kg) of tire!
Talion 6S BLX 4WD EXB 70 mph+ 1/8
- FIRMA 4074 2050KV
- FIRMA 150A ESC 150A
- Stock Fitted Pinion: 15t 1.0
- Stock Fitted Spur: 50t 1.0
- Dif Crown Gear: 42t 1.0
- Dif pinion Gear: 10t 1.0
- internal Gear Ratio: 4:3
- Final Drive Ratio: 14.33:1
- Tire overall diameter: 5.71" (145mm). Width: 2.24" (57mm), dBoots KATAR Belted MT
- Wheelbase: 14.88 in (378mm)
- Width F/R: 16.46 in (418mm)/16.34 (415mm)
- Weight Stock: 9.45 lbs (4.29km)
Typhon 6S 70 mph+ 1/8
- FIRMA 4074 2050KV
- Stock Fitted Pinion: 16T, Metal
- Stock Fitted Spur: 50T, Metal
- Dif Crown Gear: 43t 1m
- Dif pinion Gear: 13t 1m
- internal Gear Ratio: 3.3
- Final Drive Ratio: 10.31:1
- Tire diameter: 4.6" (117mm), Width: 1.7" (44mm), 1.05 lbs/quad (118.75 gm/each, 475gm/quad], dBoots Katar T 6S
- Wheelbase: 12.91 in (328mm)
- Width F/R: 12.20 in (310mm)
- Weight Stock: 7.53 lbs (3.42kg) - 1.8 lbs (820gm) of tire.
- new Tire diameter: 5.4" (136.4mm), Width: 2.8" (70.2mm), 2.13lbs/quad (241gm/each, 965gm/quad], Duratrax Sixpack MT Belt 2.8
- New Weight: 9.1 lbs (4132gm)
- new Tire diameter: 5.4" (136.4mm), Width: 2.8" (70.2mm), 2.2 lbs/quad (250.5gm/each, 1002gm/quad], Duratrax Bandito MT Belt 2.8
INFRACTION 6S - 80+ stock
- FIRMA 4074 2050Kv
- Stock Fitted Pinion: 15T
- Stock Fitted Spur: 46T
- Dif Crown Gear: 42T 0.9m
- Dif pinion Gear: 15T 0.9m
- Internal Gear Ratio: 2.8:1
- Final Drive Ratio: 8.58:1
- Tire diameter: 100mm
- Wheelbase: 15.98 in (406mm)
- Weight 11lb (5kg)
Typhon 3S - 50 mph+ 1/8
- SPEKTRUM FIRMA 3660 3200KV 4-pole, shaft 5mm, Diam. 36 mm
- BLX100 ESC 100A
- Stock Fitted Pinion: 15T 0.8 Mod (32 pitch), Metal
* Upgraded Fitted Pinion: 20T 0.8 Mod (32 pitch), Metal
- Stock Fitted Spur: 57T 0.8 Mod (32 pitch), Composite
- Dif Crown Gear: ?? .08
- Dif pinion Gear: ?? .08
- internal Gear Ratio: 2.85
- Final Drive Ratio: 7.12
- Tire overall diameter: 4.6" (117mm) (dBoots 2HO)
* Tire overall diameter: 4.2" (107mm) (Duratrax Bandito Tire C2)
- Weight Stock: 5.68 lbs (2.58kg)
- Weight with bumpers and skids: 6.55 lbs (2970gm)
Felony 6S 80 mph+ 1/7
- FIRMA 4074 2050KV
- Stock Fitted Spur: 46T, Metal
- Dif Crown Gear: F: 42T 0.9m; R: 45T 0.9m
- Dif pinion Gear: F: 15T 0.9m; R: 14T 0.9m
- internal Gear Ratio: 2.8/3.21
- Final Drive Ratio: ?:1
- Tire overall diameter: 100/107mm
- Weight: 11 lbs (5kg)
Vendetta 3S - 70 mph+ 1/8
- SPEKTRUM FIRMA 3660 3900Kv
- BLX100 ESC 100A
- Stock Fitted Pinion: 20T 0.8 Mod (32 pitch), Metal
- Stock Fitted Spur: 50T 0.8 Mod (32 pitch), Composite
- Dif Crown Gear: 37T 1.35m
- Dif pinion Gear: 13T 1.35m
- Final Drive Ratio: 10.83
- Tire overall diameter: 3.35" (85mm) (dBoots ELEVENS)
- Wheelbase: 13.19 in (335mm)
- Weight: 6.39 lbs (2.9kg)
- FIRMA 4074 2050KV
- BLX185 ESC 150A
- FIRMA 4074 2050KV
- FIRMA 4074 2050KV
- FIRMA 4074 2050Kv
- Weight 11lb (5kg)
- BLX100 ESC 100A
- FIRMA 4074 2050KV
- BLX100 ESC 100A
