Voltage Hobbies Aluminum Servo Mount for ARRMA Kraton, Talion, Typhon, Senton, and Outcast
Voltage Hobbies
Torrance, CA
  2. Talion
Voltage Hobbies is happy to introduce our new Servo Mount for ARRMA Kraton, Talion, Typhon, Senton, and Outcast. Our servo mount is made from 6061 CNC Machined Aluminum for Superior Strength and Durability.
Our full aluminum servo mount will eliminate the excessive steering flex of the original plastic servo mount, providing improved steering response and fewer chances of broken servos.
Our servo mount eliminates the use of the plastic spacers used with the original plastic servo mount, and will also fit bigger servos up to; 43.5mm Length x 21.5mm Width x 29mm Height (measured from the bottom of the servos mounting tabs to the bottom of the servo).
  • 6061 CNC machined aluminum
  • 6.3mm thick servo plate with chamfered edges on the inside and out
  • 6mm thick mounting posts
  • All mounting hardware is included
Designed and manufactured in the U.S.A.
To purchase please follow this link; http://www.voltagehobbies.com/store/c1/Featured_Products.html
