Running one 6S in my opinion is easier on the batteries. In some cases, I have drained down one cell in a dual setup and it puffed up. I have almost no issues with single setups. Also...you should run the LVC a little higher on some batteries. I run 3.5 LVC on cheaper batteries and ESC's. Or....I may use a Lipo alarm but the balance plug is hard to keep plugged in if you are jumping etc. That needs a little rigging to keep them plugged in snug.Thanks for the input. Well I'm going to give it a shot today and see how it goes. I'm on the fence about getting another 2 3s packs or the cheaper rout and change out the pinion and use 4s. But will this set up have enough power to help flip the truck in the air or do I need the 6s power for that?
It still kind of amazes me that there aren't any ESCs that you can plug the balance plug, or none that I know of, into so that it reads all of the cell voltages and shuts down when the lowest cell hits the low voltage cutoff.Running one 6S in my opinion is easier on the batteries. In some cases, I have drained down one cell in a dual setup and it puffed up. I have almost no issues with single setups. Also...you should run the LVC a little higher on some batteries. I run 3.5 LVC on cheaper batteries and ESC's. Or....I may use a Lipo alarm but the balance plug is hard to keep plugged in if you are jumping etc. That needs a little rigging to keep them plugged in snug.
Maybe I should patent my idea for the balance plug into the esc.....Thanks Vanning and Chevy. I usually stop running them around 3.6 or so then bring them back up to 3.8. Sure would be awesome to find an esc that did that. I run 2 packs because my current charger (onyx 245) only charges up to a 3s lol. Maybe in the future I'll upgrade my charger and use single packs but for now I'm stuck lol.
I should patent it and let every company use it free of charge......except Traxxas.Just for storage. I think you should mention something to Arrma about your esc idea lol.
Lmao that would be awesome!I should patent it and let every company use it free of charge......except Traxxas.
Yes. It wakes it up a lot.is it ok to run 15 tooth in a 4s kraton
Not if you have the adjustable motor mount and set the mesh correctly.can it b damaging to the gears
