They moved the whole motor mount / center diff towards the rear in the v3, and rotated the steering servo 90deg. So it looks like you would need chassis, both braces, both drive shafts, and probably the battery tray, as it has a different bolt pattern than the v1 battery tray. Not sure on the RX box, whether it will fit the bolt pattern of the new chassis, but it would be nice to have too.The chassis should work with a v1 & v2 and will be required if you want to use the new chassis braces.
Oh dang I didn't even notice that. I thought it was the Outcast battery tray?They moved the whole motor mount / center diff towards the rear in the v3, and rotated the steering servo 90deg. So it looks like you would need chassis, both braces, both drive shafts, and probably the battery tray, as it has a different bolt pattern than the v1 battery tray. Not sure on the RX box, whether it will fit the bolt pattern of the new chassis, but it would be nice to have too.
I think it is. But the Outcast battery tray has a different bolt pattern. People that have put them on the other 1/8 cars report they needed to drill new mounting holes in the chassis.Oh dang I didn't even notice that. I thought it was the Outcast battery tray?
