BLX Talion Tires keeps ripping
Discussion in 'Talion' started by Bmiller1510bandk, May 25, 2017.
  1. Bmiller1510bandk
    Bmiller1510bandk Well-Known Member
    May 5, 2017
    3
    Arrma RC's:
    Talion
    Hello,
    I have been experiencing consistent blow outs lately. The original d boots blew out the side walls... 3 in one day. I replaced all 4 with Pro-line pre mounted Badlands. On my 2nd or 3rd run, I lost half of the outer glue seal on one of them. I have noticed the front tires seem to balloon out more than the rears. Considering how every blown tire has been on the front, I am wondering if there is a cure for this, or if anyone can offer a potential solution for getting all 4 to engage equally..Not sure if it's the tires, or the distribution. Any advise?
    Thanks,
    Ben
  2. 83N
    83N Well-Known Member
    May 5, 2017
    139
    46
    UK
    Arrma RC's:
    Kraton
    Try changing your diff oils. If your front tyres are ballooning, add a thicker oil to the centre diff. It'll help keep more power going to the rear and stop your fronts deforming so dramatically. I use 100k oil in my centre diff.
    Look here for a guide.
    You could also look at taping your tyres/foams to effectively prevent them distorting so much.
    WoodiE likes this.
  3. crankestein
    crankestein Well-Known Member
    Mar 18, 2017
    164
    60
    Arrma RC's:
    Talion
    Heavier diff oil in the front, heaviest in the center (100k).
    Traxxas tire glue rated to 100+mph. Do follow the instructions, sand surfaces, clean w alcohol, glue and let cure.
    Still on 5S and 6S ballooning will happen but not as bad.
  4. Bmiller1510bandk
    May 5, 2017
    3
    Arrma RC's:
    Talion
    Thanks for the awesome information and the guide....Sound like the right place to start.
  5. Bmiller1510bandk
    May 5, 2017
    3
    Arrma RC's:
    Talion
    Thanks. I will give the Traxxas glue a try when I replace the rubbers and foams on my original blow outs. Hopefully the diff oil cures the problem.... These wheels are getting expensive for no longer than they last.
  6. Ole Fart51
    Ole Fart51 Well-Known Member
    Jul 7, 2016
    413
    318
    Louisiana
    Arrma RC's:
    Kraton, Nero, Outcast, Talion
    Iv been putting 500 thousand in center diff. Front tire ballooning is reduced a lot.
    Ajfarra likes this.
  7. Ajfarra
    Ajfarra Active Member
    May 26, 2017
    1
    WEST VIRGINIA
    Arrma RC's:
    Talion
    I'm having this same issue, I'm gonna upp my diff oil weight and order a set of SRC terrain crushers, I'll get back to yah with the results in a week or so
  8. CallmeDano
    CallmeDano Well-Known Member
    Apr 26, 2016
    Arrma RC's:
    Fury
    Get a set of truggy wheels. The solid type
  9. daniel
    daniel Well-Known Member
    Jun 30, 2017
    6
    Arrma RC's:
    Talion
    Hi there
    I have same problems on my Talion, the original dboots just blew.
    I'm going to replace tires...does anyone know if AKA 14006ZR are good on stock rim?
    thank u
Verification:
Loading...
Draft saved Draft deleted
  • Welcome to Arrma Forum
  • Disclaimer
