Talion Talion discontinued
Shiftin2sixth
So cal
  1. ADX-10
  2. Senton 6s
On tower and on Arrmas website it is not not available. Bummer. I was actually planning on a talion for my next Arrma
I stand corrected ! It was on Back Order 2 days ago? I just bought 2 so hope the parts stay around.
It's back online as Backorder. Playing with my emotions as to how long parts stock is going to last lol.
Just got an email from tower. The current Talion is going to be discontinued and a new version is coming out. It's going to be "faster" and red. It also is going to cost $20 more and coupon codes will not be allowed on purchasing it. I wonder if all Arrmas are going to follow suit with not allowing coupon codes soon.
So it will be the same price as the Kraton? And that sucks about the coupon codes :(
I guess the V3's are coming out. Wonder what all they will change? Maybe BLX200 system for Kraton / Talion / Outcast, and the Outcast battery tray / chassis guards for all cars? What else will they change? Maybe a decent servo? The current AD15 was good when it was getting fed 7.4v from the BLX180, but with the newer ESC's only having a 6.0v BEC they are slow and weak.
I kind of wish they would make a 2s version of the Senton, with a good 3660 4 pole 4000kv motor, and give it a diet to get it closer to the SCTE / SCT410 weight. Oh, and 12mm hexes. :)
They just posted a picture of the new talion on Instagram stories if anyone is interested
It's now also on towers website and unfortunately no coupon codes and it did go up $20
Tower Hobbies said:
**Additional Technical Info Will Be Added When It Becomes Available.**
This is the Arrma 2.4GHz Radio Controlled, Brushless Powered, 1/8 scale
Ready to Run Talion 6S BLX Speed Truggy with Red and Black Body.
**Newly Designed Features Include;**
Aggressive Low-Profile Body with Multi-Element High-Downforce Wing
Low-Profile Wing Mount
Low-Profile dBoots Katar Tires
Wheels Designed for On-Road Speed as well as Offroading
New Shocks with 4mm Shafts
Lower Shock Towers for Less Drag
Larger Radio Box
Shares Battery Tray, Battery Box and adlustable Body Mounts with
the Outcast 6S
Stronger Front Buggy Arms
Stronger Low Cost Front Hubs
Stronger Bulkheads
Stronger Front and Rear Braces
Stiffer Servo Mount
Something interesting - low profile shock towers? This seems like an odd choice. I know there is a growing Arrma sub-coulter of speed run guys, but for what I feel is still the Core Arrma buyer - they are the big air bashers. Check out the angle on the shocks now - almost a 45' angle. I wonder how that will effect the bashing big air guys?
I don't do instagram, but here is the Tower link. I found it by searching on Talion. That search shows the old one and the V3.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGTPM**&P=7
I just noticed the "Coupon discount not allowed by manufacturer for this product" is on there, which @Shiftin2sixth has pointed out, which sucks, but on the plus side, the "WARNING: This product contains a chemical known to the State of California to cause cancer and birth defects (or other reproductive harm). Exposure through skin contact and ingestion may occur." isn't on this one. Now I can finally eat my rc car without fear of getting cancer.
Larger Radio Box
Shares Battery Tray, Battery Box and adlustable Body Mounts with the Outcast 6S
Stronger Bulkheads
Stiffer Servo Mount
FEATURES
Chassis: 0.12" (3mm) thick aluminum
Drive: Four wheel with CVD driveshafts
Radio: Tactic TTX300 2.4GHz 2-channel with SLT (Secure Link Technology) for unbreakable link between transmitter and receiver
ADS15M waterproof metal gear steering servo, TE326 receiver
Motor and ESC: BLX185 Brushless Power System, 2050Kv brushless motor, with etched aluminum finned motor can for efficient heat dissipation, gold connectors
13T pinion gear installed on motor, 15T included in box
ESC: 150A waterproof ESC with XT90 battery connector, cooling fan, bridge connector for use with single 4S or 6S packs
Shocks: with 4mm diameter shafts
Shock Towers: New low-profile 0.20" (5mm) thick aluminum
Suspension: Pillow ball with anti-roll bar
Body: Newly designed low profile with multi-element high-downforce wing
Motor Mount: Aluminum
Battery Holder: Adjustable hook and loop straps
Tires: Low profile dBoots Katar
Wheels: Black 5-spoke, 17mm hex
Camber: Adjustable front and rear, camber refers to the angle of the tops of the tires from vertical when viewed from front or behind vehicle
Caster: Adjustable, caster/toe-in refers to the angle of the front suspension when viewed from the side of the car in relation to the chassis
Warranty: Two year limited warranty beginning at date of purchase
Looks like they've listened to our gripes with the v2!
Larger Radio Box
the Outcast 6S
Stronger Bulkheads
Stiffer Servo Mount
FEATURES
dissipation, gold connectors, 13T pinion gear installed on motor,
15T included in box
Shocks:
wing
vehicle
the chassis
Wow. And I know the Kraton is going to be getting all of the same upgrades... looks like im buying another! The talion seems more of a racer, vs the Kraton being more basher oriented.
I am VERY surprised they did not update the servo.
