On pavement like he asked? I don't think so.THE PRO LINE BAD LANDS ROCK BEST IV USED ON MANY TRUCKS
I see lots of guys using the good old faithful Proline 3.8 Badlands.... But Duratrax and Louise also do some great monster truck tyres. Try these links and see what you like...
http://www.duratrax.com/tires/3-8monstertruck.html
http://www.louiserc.com/products.php?M=0&uID=1&cID=33
Don't see your car here? Then click here for the specifications page.Would be nice if these companies would include specs (height, width, weight) on their tires.
The mx38 are really awesome traction...pretty soft tho...and big diameter so don't go with big pinionanyone used the badlands mx38 yet?
they actually do...Would be nice if these companies would include specs (height, width, weight) on their tires.
they actually do...
thanks bud!! great advice! i was considering,badland, backflip and shockwave....everyone are pointing to the back flip.because of size similarity,reinforcement rib inside,traction, durability and finally a little bit more heavy than the original one...that make for easier back flip. the only down side is that, in some case they seem to crack or tear on the edge of the wheel and you have to keep an eye open and put some ca glue as soon as you see a small sign of unglued or tear tires!! thank again!!In my opinion i would go with the dboots backflips there a solid choice . I have mx38s and 3.8 swampers and i always preferred the backflips due to the lower weight. don't get me wrong the mx38s are sensational no doubt as are the swampers but i think you may find with the dboots backflips you have more pinion size options depending on weather/outside temps, 6s driving and just how long you want its legs to be so to speak .
I find they hook up well and still let you drift like crazy of you want
Hope this helps somewhat. Solid thread going on here guys . Great stuff
youre right for the weight...i never used them...but after seeing them perform on u tube...i wouldnt consider louise for that kind of use(6 s)jumps...speed run...ive seen some unreal balloningI don't think any list weight. louiserc doesn't seem to list any specs at all.
