Lockup1109
- BigRock
- Thread starter
- #21
Im definitely trying to break that 160 mark. I love how your using a Kraton chasis and will eventually go that route.
Again i appreciate all your help.
Tppower just said its okay to change my motor... should i ask for something that can handle 12s, 16s? Lol
Unfortunately there's no real way to make a typhon handle more than 8s and 12s speed controllers will not fit unless you run a gt body. But then you will not hit more than 130 without going airborne trust me. 160 with a typhon is going to be extremely difficult. At that speed you need an aero dragster or highly customized rigid body gt. You can run 8s but 6s with the right motor and gearing will be faster because the capacity of the packs needed to run high enough amperage.
Also the 4070cm will not fit into a standard length typhon without almost cutting the rear A arm down to almost no support. It also hits the lower bulkhead mount just so you're aware. Are you running a spool?
