Sully_
OK. so i'v done some upgrading in hopes that i would have a more sound drive-train, but in turn, it seems like i may be having some issues. (story of my life)
The car seems extra loud when i give it juice, and the pinion seems to be getting eatin up by the spur gear. Although it hasn't failed , you can see actual metal dust, and the indents on the pinion. Along with that it seems to lag a little bit when i hit the throttle.. almost slipping. Is any of this normal ?
Also the slight horizontal play in the spur gear ? could this cause an issue being that its so minimal ?
Also the play in the rear drive shaft. Can this cause issues ?
My rear drive shaft also has a slight wobble to it and i will be replacing that immediately, but could that also have this big of an impact on the center gears ?
Everything else seems to be in order, so i'm kinda at a crossroads here on what the issue is. I'v included a video and a picture in this post to show you guys.
