Shock Tower!!!
Discussion in 'Voltage Hobbies' started by incam7, Jun 13, 2017.
  1. incam7
    incam7 Active Member
    Apr 6, 2017
    10
    Maine
    Arrma RC's:
    Outcast
    Where did the rear towers go! Nooooo!!! Are we temporarily out of stock??
  2. 83N
    83N Well-Known Member
    May 5, 2017
    139
    46
    UK
    Arrma RC's:
    Kraton
  3. Voltage Hobbies
    Voltage Hobbies Well-Known Member
    Oct 3, 2016
    37
    62
    Torrance, CA
    Arrma RC's:
    Kraton, Senton, Talion, Typhon
    They are temporarily out of stock. We are going to be restocking asap. Thank you for your interest!
  4. Crash
    Crash Well-Known Member
    May 24, 2017
    174
    108
    Saturn
    Arrma RC's:
    Kraton
    Any chance you guys could make a tower tower brace?
    83N likes this.
  5. JustinK
    JustinK New Member
    Jun 10, 2017
    Arrma RC's:
    Outcast
    I'd also be interested in a tower to tower brace. You could create one that's custom fit to your tower designs.
    Really liking my Voltage Hobbies servo saver by the way, great design!
    Voltage Hobbies likes this.
  6. Voltage Hobbies
    Oct 3, 2016
    37
    62
    Torrance, CA
    Arrma RC's:
    I don't recommend the use of a tower to tower brace as it makes the towers and gearbox cases more likely to bend/break under hard impacts/crashes, the reason is most of the energy gets transferred directly to those two parts. I've tested out a tower to tower brace and it does lead to broken gearbox cases and bent shock towers from my testing. Even high-grade aluminum or carbon fiber shock towers are still prone to bending or snapping (it takes a lot more force for it to happen, but it does).
    I'm planning on releasing either a full chassis plate that's made from thicker higher grade aluminum than stock or a full-length skid plate that helps reduce the excessive flex of the stock chassis plate. I'm hoping to bring one of the two to market soon.
    #6 Voltage Hobbies, Jul 16, 2017
  7. JustinK
    JustinK New Member
    Jun 10, 2017
    Arrma RC's:
    Outcast
    Excellent, thanks for the heads up, much appreciated.
  • Welcome to Arrma Forum
  • Disclaimer
