servo suggestion without BEC
silver5
  1. BigRock
  2. Nero
Hi, I am looking for a decent servo that I can use with my MM esc without having to get a BEC. Any suggestions?
So far I know is there no servo available which can handle 4 or 6S without BEC.
One other way is using a 7,4V Servo and a separate 2S batterie. But you have to disconnect the red (+) cable from the receiver to the servo.
The esc has a built in bec I think
I recommend at least a 20kg servo at 6V. The speed depends on your budget. I recommend a faster one than the stock i.e. <0.15s.
@Fiery
I also don´t know from an servo with inbuild BEC.
I guess that he will have an high torque servo and keep out the receiver and ESC out of that powerline.
I have an Corally servo (18Kg on 6V), but I have to maintain the diff locks before I can make a test run. First Impressions are quite good. Much more faster and more torque on the paper. We will see.
