Raji
Hi everyone,
These are recommendations for the Arrma Outcast springs and shocks oil. I collect comments from members here in the form and Youtube. I make it easier for you
-I'd recommend just a slightly stiffer set overstock and use 90k front/75k rear shock oil
-Stiffer springs help reduce after bounce with bigger landings. As far as front dipping and break flipping, my Orange Teknos have vastly improved this running in rough, loose, and high traction surfaces. A lot of this boils down to driving style and personal preference.
-I'm running 70 in the front and 55 in the rear I'm hoping the Tekno orange springs will suite!!
-70/60 oil on stock springs
-I went with Yellows all around, and 1000CST shock oil in all four.
the yellows with the thicker oil provide nice damping without too much stiffness.
I have my preload set to about 3/4 of max.
Good ride height handles well, absorbs bumps very nicely.
I also set my shock rebound to almost max, which keeps the tires planted over bumpy terrain, and levels the truck out nice and quick under transitional steering/maneuvers.
-Tekno orange up front and yellow in the back.
-Tekno Orange in front and Yellow in back. Tried 50 front and 40 back
-50-60 front with Tekno oranges, 40 rear with yellows has been way better overall, far less breakages and better handling
-orange fronts with TLR 60 oil, yellow rears with TLR 50
-For my shocks I am running Tekno MT410 shocks in the front with Tekno orange springs TKR6093 and 60 wt Associated shock oil. The rear shocks are stock Arrma shocks with Tekno orange springs TKR6083 and 50wt shock oil. Shocks are perfect except I keep breaking shock pistons on the rear. Going to go for the Tekno MT410 shocks in the rear as well.
That all Have fun.
That all Have fun.
