Talion New talion coming
**Additional Technical Info Will Be Added When It Becomes Available.**
This is the Arrma 2.4GHz Radio Controlled, Brushless Powered, 1/8 scale
Ready to Run Talion 6S BLX Speed Truggy with Red and Black Body.
**Newly Designed Features Include;**
Aggressive Low-Profile Body with Multi-Element High-Downforce Wing
Low-Profile Wing Mount
Low-Profile dBoots Katar Tires
Wheels Designed for On-Road Speed as well as Offroading
New Shocks with 4mm Shafts
Lower Shock Towers for Less Drag
Larger Radio Box
Shares Battery Tray, Battery Box and adlustable Body Mounts with
the Outcast 6S
Stronger Front Buggy Arms
Stronger Low Cost Front Hubs
Stronger Bulkheads
Stronger Front and Rear Braces
Stiffer Servo Mount
FEATURES
Chassis: 0.12" (3mm) thick aluminum
Drive: Four wheel with CVD driveshafts
Radio: Tactic TTX300 2.4GHz 2-channel with SLT (Secure Link
Technology) for unbreakable link between transmitter and receiver
ADS15M waterproof metal gear steering servo, TE326 receiver
Motor and ESC: BLX185 Brushless Power System, 2050Kv brushless motor,
with etched aluminum finned motor can for efficient heat
dissipation, gold connectors, 13T pinion gear installed on motor,
15T included in box
ESC: 150A waterproof ESC with XT90 battery connector, cooling fan,
bridge connector for use with single 4S or 6S packs
Shocks:
with 4mm diameter shafts
Shock Towers: New low-profile 0.20" (5mm) thick aluminum
Suspension: Pillow ball with anti-roll bar
Body: Newly designed low profile with multi-element high-downforce
wing
Motor Mount: Aluminum
Battery Holder: Adjustable hook and loop straps
Tires: Low profile dBoots Katar
Wheels: Black 5-spoke, 17mm hex
Camber: Adjustable front and rear, camber refers to the angle of the
tops of the tires from vertical when viewed from front or behind
vehicle
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to
the chassis
Warranty: Two year limited warranty beginning at date of purchase
70mph out of the box! Still with the 15t pinion, interesting. Kind of suppressed they kept the BLX185 - I though they would go with the BLX200 system. That makes me wonder what the real power difference is between the two?
For general backyard bashing...This one in October or the Kraton now?? What do you suggest?
For general bashing, I like the Kraton over the Talion. I had both for a while, and traded the Talion for a Typhon, still have the Kraton. :)
With that said, some of the upgrades would be nice to have. Stiffer servo mount, outcast battery tray. Also, by October, they bay be teasing the V3 Kraton, Dec release. LOL Then what you gonna do?
:D
I doubt it is lighter by much, maybe a few oz due to the shorter shock towers. I would expect the old shock bodies/pistons/lower eye / anything that touches the shock shaft will need to be replaced to use the new shocks. Considering the 'old' shocks are $85 a pair, but race-grade Tekno 'full option' truggy shocks are $95 retail / $45 from a chop shop, I don't see the new shocks as a upgrade path.
I don't dig the new color scheme though, the old one was cool and original, the new one is common, and probably harder to see...
I wish all RTR came with at least the body unpainted.
I'll say its to fit the steering servo the other way....
Noticed the manual says typhon and senton shocks getting plastic caps etc... While the others keep the alloy bits.
Interesting that the video was removed.. Maybe posted a little too early? At least this confirms that there WILL be new 2018 models across the line. I think Arrma is trying to sell the old stock before they announce anything.
