Typhon New Poseidon motor leads not marked?
Brakemanbobsmith
Ohio
  1. Raider
  2. Talion
Ok putting in a new Poseidon 2200kv motor #P1515 in my sons Typhon and found the leads on motor are not marked A B or C ?
How do I know which lead goes where?
And will it hurt the motor or ESC if they are not pluged in right? Or will motor rotation just be backwards?
I also put in a Hobbywiing ESC
and need to know which spot on the 3 channel reciver dose it plug into B 1 2 or 3?
He brought me car with everthing removed so now I'm trying to figure everything out.
Thanks for any help.
just plug it in any way. if the motor spins the wrong way just swap any two wires and it should be right. you won't hurt anything by doing this.
b is for battery,you don't need to use it. 1 is always steering and 2 is your speed control.
Thanks
I thought that was the way it works, just like any 3 phase motor.
Just wanted to make sure and not screw up a new motor lol
Learning everyday!
Appreciate your help.
Is this on the stock esc? I'm wondering about dropping the 1515 into my outcast now.....
No was using a 150amp Hobbywing ESC, now installing a Momda Monster XL
