New Kraton owner
Discussion in 'Kraton' started by Wippersnapper1992, Dec 5, 2017.
  1. Wippersnapper1992
    Wippersnapper1992 Active Member
    Dec 2, 2017
    3
    Arrma RC's:
    Kraton
    Couple of questions..Wanted to get back into RC as haven't used one since I was a kid. I've brought the arrma 2018 Kraton which is not anything like the electric cars I used to zip around my garden so I'm deffo a newbie but my god I'm loving it, been out everyday 3 times a day since I got it. Got 2x overlander 3s 5000mah lipo packs but already they are beaten abit and one has a small dent in the side. After reading up stuff on the internet that scares me a little, I'm constantly sitting by the charger watching the packs while they both charge one after another. I was firstly wondering if I should worry about small dinks in the battery's?
    Also wondering if it's benifical I get a hardcase lipo? Although I don't think I'd like not being able to see the cells for ballooning
    Lastly any recommendations for 6s packs? Can you get hard case 6s pack around the 5000mah mark that will fit in the beast?
    Any advise would be great
    Thanks
    Matt
  2. Dietrich_40
    Dietrich_40 Active Member
    Oct 23, 2017
    41
    9
    Arrma RC's:
    Kraton
    Check out SMC. A lot of bashers use their hard packs. I run two 3s 60c 7200. Plenty of power and 30+ min run time. I opted for the traxxas connectors to go with my traxxas live charger. It's cheap and I can monitor with my phone.
  3. Brker
    Brker Active Member
    Nov 25, 2017
    15
    Arrma RC's:
    Kraton, Talion
    Same. I went with the 5400 SMC 3s lipo’s. One strap doesn’t fit around both batteries when running 6s, but the other does. Stays put. Although every time I run 6s I break something. Keep it on grass and off pavement.
  4. dpricenator
    dpricenator Supporting Member!
    Supporting Member
    Oct 25, 2016
    997
    753
    Arrma RC's:
    Kraton
    Lots to read on this forum. YOur best bet is to lock your credit card up, before you see all the goodies you are going to want. Some you need and some you don't. YOu need to shim your differentials. Since you have a V3 Kraton you don't have to upgrde to an aluminum servo mount, but might want to. Anyhow, you will be able to see a Hard case battery puff. The case will stop being flat, and the case will separate. Pretty obvious in a soft or hard pack.
Verification:
Loading...
Draft saved Draft deleted
  • Welcome to Arrma Forum
  • Disclaimer
