My soldering Iron is dying
Discussion in 'Tools' started by Corider, Dec 30, 2016.
  1. Corider
    Corider Well-Known Member
    Dec 11, 2016
    57
    51
    Castle Rock iColorado
    Looking for advice. My soldering Iron is dying and not getting as hot as it used to. Does anyone have any suggestions on a quality,budget friendly soldering station. Or if not budget friendly something that has a good chance of lasting until the end of time? Thanks in advance.
  2. WoodiE
    WoodiE Kind of good admin
    Staff Member
    May 14, 2015
    1,847
    1,291
    Lexington, KY
    @Corider I'd suggest checking out the Hakko Digital FX888D. For the price you'd be hard pressed to find something better. It'll cover all your RC and other soldering job needs.
    Paulie, Dustin Mustangs and Corider like this.
  3. Corider
    Dec 11, 2016
    57
    51
    @WoodiE,
    That looks like the perfect option, I really appreciate your input!!
  4. Dustin Mustangs
    Dustin Mustangs Supporting Member!
    Supporting Member ArrmaForum Fan
    Jun 9, 2015
    438
    287
    I have the same one but non-digital. Very nice unit. Get yourself some rosin core 60/40 and the thing pretty much solders things for you. I just have to hold the beer.
    Corider likes this.
  5. Corider
    Dec 11, 2016
    57
    51
    I appreciate the input. I was looking at the non-digital to save a few bucks. Great information, Thank You!
  6. Jerry-rigged
    Jerry-rigged Well-Known Member
    ArrmaForum Fan
    Apr 27, 2016
    376
    228
    Texas, Baby!
    crankestein likes this.
  7. Paulie
    Paulie Well-Known Member
    Dec 14, 2016
    59
    25
    VT
    You can replace the heating element in most soldering irons.
  8. JoshHefnerX
    JoshHefnerX Well-Known Member
    Dec 28, 2016
    68
    20
    Glendale, AZ
    I'll 2nd the hakko, just make sure you get an assortment of tips.
  9. TwiZted SkullZ
    TwiZted SkullZ Well-Known Member
    Jan 4, 2017
    146
    168
    The Red Rocks of Utah
  10. Jerry-rigged
    ArrmaForum Fan
    Apr 27, 2016
    376
    228
    Texas, Baby!
    80W is a lot for and unregulated stick iron. Plus that huge tip will be in it's own way. 40w or 60w with a 1/4" or 1/8" chisel tip would be better. for 12g and smaller, the 40w will work. for 10g work, the 60w is better.
    I used this $13 iron for many years -
    https://www.radioshack.com/products/40-watt-pencil-iron
    I even used the pointed tip that everyone seems to hate.
    While looking for a link to that iron, I saw this $25 Adjustable iron - https://www.radioshack.com/products/radioshack-multi-watt-soldering-iron RS even has a tip kit for it with a nice small chisel tip for $5 - https://www.radioshack.com/products/radioshack-soldering-iron-replacement-tips
    Plus you will want an iron holder - the little wire prop that comes with cheap irons is useless.
    https://www.radioshack.com/products/radioshack-soldering-iron-holder
    Up to 50w max, adjustable, for about $40 with the tip kit and stand, seems like a deal if someone does not want to jump into a full soldering station.
  11. Brakemanbobsmith
    Brakemanbobsmith Well-Known Member
    Mar 6, 2017
    36
    Ohio
    If you soldering iron has a removable tip sometimes it builds up a coating on it and will not conduct heat as well as it did.
    Try removing the tip(make sure it is cool and unplugged) then clean the whole tip with a fine sandpaper, then roll sandpaper up into a small enough tube to slide up into the hole the tip came out of and sand it clean also. Wipe tip off blow out hole and use a Q-Tip to clean it out. Reinstall tip and give it a try. Not a guaranteed cure but has worked for me and could save you a few bucks.
    solidbase likes this.
  12. crankestein
    crankestein Well-Known Member
    Mar 18, 2017
    135
    47
    Harbor Freight, reliable and cheap, make sure to use their coupon codes and catch on the way a free measuring tape or flashlight, lol.
    I even got a spare just in case mine dies in the middle of the night doing minor soldering work.
Verification:
Loading...
Draft saved Draft deleted
  • Welcome to Arrma Forum
  • Disclaimer
