Kraton vs. Fazon
Discussion in 'Kraton' started by Ianscott77, Sep 13, 2017.
Tags:
  1. Ianscott77
    Ianscott77 Well-Known Member
    Sep 12, 2017
    14
    3
    philadelphia Pa
    I'm about to purchase my first Arrma and found two pre-owned options available. The first is a 1 month old V2 Kraton with around 10-15 runs on it for around $325. The other is a Fazon with 5 minutes run time for around $425. I'm aware of the litigation surrounding the Traxxas lawsuit and the Nero/Fazon models. Any help on which direction to go and why is much appreciated.
  2. dpricenator
    dpricenator Supporting Member!
    Supporting Member ArrmaForum Fan
    Oct 25, 2016
    866
    622
    Kraton HANDS DOWN! of course I do not own a Fazon, but just looking at all the "features" on the Fazon is enough for me. The Kraton is a super simple design that is tough as nails. Less to go wrong on the Kraton. Also you will have $100 left over to buy an aluminum Servo Mount and some aluminum chassis braces. The kraton is lighter, making it easier to and the big jumps. Oh yeah, in case I didn't mention it. BUY THE KRATON.
    GUSI RC, Rademf and TheMightyAtom like this.
  3. Ianscott77
    Sep 12, 2017
    14
    3
    philadelphia Pa
    Thank you - I appreciate the guidance!
  4. KrazyKraton14
    KrazyKraton14 Well-Known Member
    Sep 11, 2017
    67
    15
    Central NJ
    Kraton ftw!...specially now im building mine slowly..lol
    Rademf likes this.
  5. Ianscott77
    Sep 12, 2017
    14
    3
    philadelphia Pa
    Very nice. Just agreed to the Kraton, picking it up tomorrow after work.
    Rademf likes this.
  6. ccattie
    ccattie Well-Known Member
    Dec 20, 2016
    23
    Wyoming, Delaware
    I have both, if I could only have one, it would be the Kraton.
    -c
    dpricenator likes this.
  7. dpricenator
    Oct 25, 2016
    866
    622
    And that is the proof.....
    You're going to have a blast. FIRST THING - - Aluminum servo mount, and Upgraded Springs. Then Chassis Braces.
    Rademf likes this.
  8. gsxr750weaver
    gsxr750weaver Well-Known Member
    Jan 13, 2017
    13
    4
    Pittsburgh
    My Kraton and Talion by far crush my Fazon go Kraton
  9. 83N
    83N Well-Known Member
    May 5, 2017
    138
    45
    UK
    Wait a bit and buy a v3 (4mm shocks/ Outcast battery tray/ Stronger chassis braces/ stonger servo mount).
    Most of the weaknesses on the Talion/ Kraton seem to have been taken care of, further increasing the outstanding value represented by the Kraton platform.
    The Nero platform used by the Fazon seems to have some inherent weaknesses that IMO are unacceptable on such an expensive truck.
  10. Ianscott77
    Sep 12, 2017
    14
    3
    philadelphia Pa
    I picked up my V2 Kraton (pre-owned) last night. It's in good shape overall, so I thought $300 was worth it. Overall it exceeds my expectations...it's a beast. It tore through the wet grass and handled the new bmx jumps I bought with ease. My neighbor, a Traxxas fanboy, had 3 fixes to his Slash and Stampede inside of the 30 mins that we ran. I hope to convert him to an Arrma fan.
    I did notice the servo seems a bit unresponsive, so I'm not sure if that's how a 1/8th scale drives (compared to my brushless Stampede) or if it needs to be replaced. It doesn't like to return. It also has a little delay from when I make the adjustment on the transmitter to the action on road. Again, I'm new to a bigger and heavier rig, so that may just be the way it is.
    I can't wait to find some interesting terrain and let this thing loose.
  11. dpricenator
    Oct 25, 2016
    866
    622
    That’s a clean looking rig for $300. I would say you scored.
    The Servo is a weak link in the kraton. You can buy replacement stock servos for about $20 on Ebay. However there are several threads here regarding better servos. For less than $100 you can get a SAVOX that will put out 2x the torque 50% faster than the stock servo has. I went with the Savox 12 10 SG, because it is water proof. Now I wish I had not gotten the waterproofing, as I justdon’t live somewhere that gets all that much rain. And even if I do drive in the rain, it’ll just be on wet asphalt, and even non-waterproof servos can handle that.
    If you care, this is a good deal on a light weight 6s battery.
    https://www.amazon.com/gp/product/B01LVUPI52/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
  12. Ianscott77
    Sep 12, 2017
    14
    3
    philadelphia Pa
    Thanks, I checked it over really well. It was super clean on the inside, and the body had minor scuffs. The tires are a little beat up, but that's to be expected. He said 15-20 packs through it, and given how tough these things are, I figured $300 was a good buy. I may upgrade to Pro-Lines but I'm not 100% sure which, I think Badlands would be the right way to go. I'll check the battery as I only have two 2S batteries, and 1 3S. I was considering getting another $30 3S batter and pair it with the one I have. Either way I'm glad I made the decision.
  13. Jerry-rigged
    Jerry-rigged Well-Known Member
    ArrmaForum Fan
    Apr 27, 2016
    476
    283
    Texas, Baby!
    Yeah, the stock AD15 servo is weak on 6.0v. I have a Savox 2270SG in my Kraton. As to the Waterproof, min is not spec'ed as such, but has been under water a few times. :)
    Also, even with a better servo, the servo saver needs to be tightened down a bit to rotate those huge tires. Adjusting it involves (truck powered on) steering right, inserting an allen key into the hole in the bottom of the chassis to stop the nut from turning, steering left, remove wrench, repeat. I forget which direction tightens / loosens, though. You want the nut to be about 3-4mm off the chassis. If it is 1-2mm off the chassis, the wheels won't turn much when the truck is sitting still, or at full power. At least, I need that gap on my V1.
  14. occi
    occi Well-Known Member
    Aug 30, 2017
    1
    I own em both too and if I could only have one it would be definitely the fazon.
    Kraton has diff-outpost-issues + diff issues
  15. gsxr750weaver
    Jan 13, 2017
    13
    4
    Pittsburgh
    in my case it would be a toss up between my kraton or my nero
  16. KrazyKraton14
    Sep 11, 2017
    67
    15
    Central NJ
    I paid $120 for Hit ch one and it was well worth it
  17. Ianscott77
    Sep 12, 2017
    14
    3
    philadelphia Pa
    Perfect, thanks for the help. I see you have a Slash in the photo. How would you compare your Kraton to the Slash?
  18. KrazyKraton14
    Sep 11, 2017
    67
    15
    Central NJ
    The slash is good i bought it for my little guy.
    I feel that it needs a wider tire when you play on the grass fields. Cuz sometimes if flips (like those ford explorers back then ). But on sand and gravel its perfect.
    Yeah
    Stables consist of
    X01 with upgraded motor n parts
    Kraton
    Stampede (picking it up today with new motor)
    Slash
Verification:
Loading...
Draft saved Draft deleted
Users found this page by searching for:
  1. arrma vs traxxas lawsuit
  • Welcome to Arrma Forum
  • Disclaimer
