70 sounds great for the Back flips, looking for tires for my KratonSo, your saying shockwaves are better than backflips and you don't own the shockwaves? And you say backflips balloons to much? Do you own any backflips? I happen to own both. Shockwaves are pretty good, but not for long. They blow apart on trucks capable of speeds over 50 mph. Backflips on the other hand, hardly balloon, traction and overall performance is incredible. I have them on 3 trucks that run 70mph plus. Not one failure. This review is from tires I have owned. To be honest, Redcat Avalanche tires out perform and outlast the shockwaves.
So i just got the backflips and i haven't been able to do any backflips yet
Im on 6s 60/100/60k
Check your punch settings maybe? 100k isn't that much either for such a large truck, going 500k would probably help.
I'm guessing that the 14t pinion is more of the problem. The 12t will give more torque, aka more wheelies and rotation for backflips, while the 14t is more for speed and will give you less torque. Try the 12t pinion and see if that helps.I do not know which settings those are, how do i check that? Is that gearing?
When i had stock diff fluids on 6s it was able to wheelie instantly and to the end of the street without fail, now that i have changed the fluids it wheelies only sometimes, although it does have a 14t pinion now as well
Which backflips are you guys running on the Kraton 6s?
Looks awesome. How did you get the white walls? That custom?Welcome.... there here. They are great and come with the vent holes drilled:
https://www.amainhobbies.com/arrma-...monster-truck-tires-black-2-ara550050/p788658
pic
https://www.arrmaforum.com/threads/january-2022-rig-of-the-month-rotm-contest.47636/post-669442
pic
Truck looks awesome, thanks for the tip. Got a kyosho optima legend series and one thing i really wanted was to get the “sand super” white walled like the originals back in the 80s, now I know how. do you like the LP backflips over the full size for 6s just for looks or is the low profile better running for you? I could see some advantages with the LP in adding some zip and nimbleness possibly. Couldn’t tell but the thread here ( pretty old) seemed like most were running full size back flips, no?Someone else asked the same, posted it here. Sharpie oil pen...
https://www.arrmaforum.com/threads/january-2022-rig-of-the-month-rotm-contest.47636/post-680387
Thx
