Skaxis
- Fury
So, I got to drive it a few times over the last month or so...
First impression was great, but now I'm getting more and more disappointed in the vehicle...
I only drive on a somewhat rough field of grass near my house as I have to drive after work time and it still gets dark fairly early .
Grass is going to be harder on your SCT than on say a monster truck with much larger tires. Even if the grass is cut short, the stock Fury tires are simply not designed for such terrain. If you want to drive in a grass field I strongly suggest getting a full set of Pro-Line Badlands. Arrma SCT rims frequently go on sale at Tower Hobbies, sometimes for as low as $2.99/pair! Like right now!
Just some cruising around, no jumping or hard bashing.
It flips over almost every time I try to corner with more than 25-30% throttle.
This is called traction roll. There are ways to alleviate it. Go slower in turns is the most obvious. Suspension tuning can help. Driving on lower traction surface like loose dirt will also reduce the likelihood of traction rolling.
Going over 60-70% of throttle makes it lose all grip and spin out.
This is either the tires have poor grip for the surface, you are overpowering the truck for the level of traction you are running on, or you have too thin oil in the differential and you're "diffing out" under power. I'd suggest rebuilding your differential using 7K CST differential oil.
Out of the 7 or so times I took it out I broke 3 lower front A-arms and popped one of the front shock caps off 4 times (3 of them when I broke the A-arms).
Breakages happen when you hammer these things.
Even though it is pretty cold (5 degrees celcius), I did not expect this much breakage.
What I did notice is that all A-arms broke at the exact same spot, the "eyes" that attach it to the chassis broke right off of the rest of the arms.
The plastic will become more brittle as the temperature drops. If you are close to freezing temps I suggest taking things a bit slower / easier on your truck or invest in a lot of spares!
Managed to get this breakage without even jumping it, just from flipping/rolling when cornering with too much throttle (!)
Now I start getting afraid of actually using or jumping the truck...
I wouldn't shy away from using it. Just be a bit more gentle when it's really cold out.
On the roughest parts it is near uncontrollable, bounces everywhere, even my cheap Tamiya DT-03 drives better on those parts than the Fury.
So, I probably won't take it out anymore until the weather gets a lot warmer, see how it handles then...
If your DT-03 is equipped with CVA dampers (oil filled) then those shocks are far superior to the Arrma ones. The DT-03 is much lighter than the Fury so the impacts aren't carrying nearly as much mass. If you're using the typically included "silver can" stock motor in the DT-03, that's a 27T brushed motor. It's easily 1/4 as powerful as the brushless motor in your BLX. So it's really apples and oranges comparison here. Of course the DT-03 will fare better. It's lighter and slower with better shocks!
I'd suggest that you keep running the DT-03 when it's cold out. Rebuild your Fury shocks using 300-350 CST oil in the rear and 400 CST oil in the front. Get the Badlands tires and be a little more gentle with the throttle in the corners.[/QUOTE]
