Kraton Building my Kraton
Kraton fits fine. 9200 smc
Maybe 1/4” in taller but thats it
Yeah it fits the Kraton battery tray perfect. I was hoping it would fit the Outcast battery tray becuase i have my Kraton swapped with the Outcast tray. I geuss ill just have to switch back to the Kraton tray to run this battery. Or i could just squeeze it in the outcast tray but it seems to put pressure of the Lipo and i don't think thats a good thing.
Such a big & heavy battery adds a lot of strain to shocks, chassis, drivetrain...
It doesn't seem to make a big difference with the added weight. My Kraton preforms fine with it. Its not much heavier than my 2 3s 6700mah packs.
Broke my steering screw in 1/2. So just unwind it.
Got4 more 7200 3s at Smc
And got a few Power Hobby also for my little guy
Do the 7200s fit the kraton side by side?
Yes u do sideways not on top of each other but side by side.
Swipe Left Late night fun with the Fam
Got me a powerHobby Battery was cheap 4s 5200mah 100c burst only last me 18mins vs my 6700-9200 last me 35-45mins.
Got 4 more Smc 7200 3s also today
Total Batteries now-
Hmmmm
SMC
4x 4s 6700
2x 4s 9200
2x 4s 5200 powerhobby
5x 3s 6700
4x 3s 7200
1x 6s 9200
1x 3s 5000 reaction
Broke my servo (gear bearing shredded) and Receiver stop working on longer distances so went to shop to replace them on kraton today
Some
Fun in the dbxle
Do you still have the kraton battery tray In?
I replaced it with the outcast tray and sides and my smc 7200's only fit one on top of the other..
Yes still have it haven't replaced it
Trust me when I tell you this, that other pinion will not last long. Get a Robinson Racing pinion put threadlocker on the motor shaft as well as the grub screw.
What racing Robinson pinion should I put on my kraton v2 it’s stock ?
What size where you running before? I think the stock pinions were 12t with a 16t speed pinion. If your temps were fine with your current pinion stick with the same size.
What pinion you recommend I use on my kraton v2 all I run is stock tires and trencher 40 series occasionally?
What shocks do you have I see that there colored green and what shocks you recommend I use for light -hard bashing ?
I wouldnt go bigger than a 14t with 40 series. I run a 13t and 14t with my 40 series trenchers. The 40 series are bigger in diamter than the stocks.
When you use the 4s 6700's in your kraton, what do you use to keep them from sliding around ?
BRoke 2 servos this weekend
Servo broke on Kraton and DBXLE. POWERHOBBY COMES THROUGH with parts asap same day pick up.
Came to get servos n ended up with a few more
I havt gear 1t down from stock if u running trencher tires
I have green for Front and Orange at the back TEKNO SPRINGS
Oh i don't use 4s bud only 6s or series. 4s is for my Losi dbxle
Some stuffs done and extra bag of poop pkg came in for back ups
Losi dbxle got New Servo Savox 0236 x Led Bar x New Wing to Fly
Arrma Kraton got New Hitec 7954sh and Xcon truggy tires (love them)
Hey thanks a lot for the info much appreciated?
Your welcome, your best bet is to run the truck with a 14t and check motor temps. If the motor and esc are getting to hot, then go down a tooth. Then run it again and check temps and so on. Your motor shouldnt go above 180f....
What's up guys?? So I'm finally thinking about cleaning my diffs for the first time...was curious if anybody had any suggestions about oil weight setups...
What's the stock setup anyway?
I have a little makeshift track behind my house in the yard...dirt and grass mainly
