I have both the ET and NT shocks as well and they are the same length. Are you sure your short ones are not EB or NB?
The difference is truggy or buggy length shocks. I would think that the buggy shocks would be a better fit for the typhon.
This is from Tekno's website:
Available in 3 different shock lengths (measured shock cap center to pivot ball center):
107mm (SCT410/SCT410.3/EB48/EB48.2/EB48SL/NB48 front shock)
122mm (SCT410/SCT410.3/EB48/EB48.2/EB48SL/NB48 rear shock, ET48/NT48/EB48.3/NB48.3 front shock)
137mm (ET48/NT48/EB48.3/NB48.3 rear shock)
Pictures of "Kraphon" with Tekno full option shocks. Enjoy! .......I sure am......
These are 100% bolt on in the back (122mm) and 95% bolt on in the front (107mm). You will need to take a hobby knife and trim a very small amount of the A-arm to make the beefy tekno rod end fit on the front (see red arrow). It's super easy and takes about 1 minute to do. Don't forget to get a 4mm drill bit to drill out your shock tower holes.
It's an awesome upgrade. See the following post for how I feel about these shocks. In short, it transforms your buggy or truck. They are worth every penny.
https://arrmaforum.com/threads/tekno-shocks-on-kraton-i-had-no-idea.4064/
Man those look great!
Yes, it works the same, and the 4mm holes must be drilled. I also will add, I bought the normal stand-offs which fit, but clearance was very tight, like paper thin. I have since switched to the extended version, but I don't think it really matters much for my uses...Will 107mm and 122mm shocks fit as good on a stock Typhon?
Will those shocks fit on a stock Typhon as well? Is the 4mm drilling required by the Tekno shocks stand-offs?
Mine came with the green springs...HTHWhat springs come on these??
I just got some tekno yellows for my kraton and theyre very nice so want the same for my typhon... The site i got them from have shorter ones listed but no pound rate stated like the longer ones...
Any part numbers??
That looks so SWEET!!! Killer job brother. Know I'm late to the party, but holy cow did you build an AWESOME Truggified.Pictures of "Kraphon" with Tekno full option shocks. Enjoy! .......I sure am......
