Best pinion to run in Outcast?
Discussion in 'Outcast' started by thatyellowjeepguy, May 18, 2017.
  1. thatyellowjeepguy
    thatyellowjeepguy Well-Known Member
    May 18, 2017
    42
    USA
    is the 16t ok to run for bashing also? Is there a happy medium between the 12 and 16t. Also what's a good aftermarket pinion to get that's stronger than an arrma pinion. Part numbers would be appreciated!
  2. Mikuri
    Mikuri Well-Known Member
    Jan 15, 2017
    126
    45
    Qu├ębec
    The highest you can without overheating :p
    There is a pinion for about every tooth from like 10t to 22t from Arrma, but you could try Tekno pinions if you want another brand. They have from 11t to 30t :p
    thatyellowjeepguy likes this.
  3. Rich Duperbash
    Rich Duperbash Well-Known Member
    Nov 15, 2016
    748
    947
    Roseville, CA
    I've run the 16 tooth almost since day 1 on 6s, awesome fun, no heat issues to speak of. Robinson Racing Extra Hard, #1216.
    Buck likes this.
  4. Hypnotoad
    Hypnotoad Well-Known Member
    Aug 1, 2016
    123
    55
    Wisconsin
    I run a 15 tooth Tekno mod 1 pinion on mine. Not much difference between that and a 16 tooth. No overheating and good speed and torque
  5. slpcrf450x
    slpcrf450x Well-Known Member
    Jan 2, 2017
    176
    78
    I have a 14 in mine. I think your driving style will determine how hot you get. My motor was getting too hot with the 16 tooth. I tried it on both the 185 motor and the blx200. You'll just have to try it and see how hot you get. For me the 14 tooth is still wildly fast.
    Rich Duperbash likes this.
  6. Drew82302
    Drew82302 Well-Known Member
    Mar 21, 2017
    4
    Bensalem, Pa
    I honestly like running my outcast with the 14t. The 16t my motor was getting way too hot
  7. jonUF02
    jonUF02 Well-Known Member
    Dec 14, 2016
    206
    90
    Orlando, FL
    Monitor your motor Temps with IR heat gun after a good run. Try to stay under 180 max temp. Each tooth you step down will probably lower temp about 10 degrees. The one you end up with will depend on your conditions and driving. Robinson Racing extra hard is the way to go. Part number 12XX depending on tooth number.
  • Welcome to Arrma Forum
  • Disclaimer
