mansour545
- Fazon
Hi guys
It have been long since my last post and I have upgraded my Fazon a lot
Traxxas lock pins for all 4 CVDs and 2 Diff drives TRA5145
Hot racing CVDs NRO288V02 in front
Hot racing CVDs NRO200E02 in the back
Aluminum rockers NRO27M01 X 2 sets for all wheels
Leopard motor LBP4082/2Y 1600kv for higher torque since the Fazon is pretty heavy
Hot racing Pinion gear 26T mod1
Arrma steel spur Gear AR310729
EVO P2 brushless servo
T-bone Thrasher for nero platform 10039-TBR
Badlands MX38 3.8" tires x1 set
Proline slingshot 3.8 tires x1 set << for sand bashing
I have NOT regret any of these parts "yet"
For the Badlands tires I couldn't use them freely because of the ballooning issue so then I used the kevlar threads with little drops of super glue on the strapped threads like every 3cm that will to make the kevlar reinforced and strap them on the tire between the tire treads shown in the video is the comparison.
I really recommend doing it it will really make you get full advantage of the tires using all the surface. I tried them on hard terrain and sand and tgey are doing pretty great no cuts no loose straps at all.
I don't recommend doing that for speed runs on asphalt though it might not be efficient I don't know.
Let me know what you think?
