arrmageddon's TALION
I think i can charged lipo up to 10a
I forgot already lol
Question here
Im using a max8 combo
It came with a cap pack
Must i use it or not?
Re: Cap pack, I have no idea... LOL I think it is used as a 'glitch buster' and to prevent brown-outs with some high power servos.
Charging - if your battery is 5000mah, and you push 10 amps, in theory, you will charge the battery in 30 minutes. In realty, it will take a bit longer as the charger ramps the amps down near the end of the cycle...
What is the wattage for the charger?
I have the Dynamite Prophet Sport Duo - a step down from yours. Mine is 6a/50w per channel. So 2s, I can push 6a, but 4s, I max the wattage out at 3.2 amps (I think that is right). also worth noting - If I charge (2) 2s packs at 6a in my warm garage, the charger overheats, and shuts off one of the channels... So pay attention to temps if you charge 2 packs at full amps.
Servo, servo horn led lights for my tf2 :D
Now i need to order my lipo and charger
Im in a bit of a jam here
The legs of the servo mount is a bit short from the original servo mount
I need to use washer to lift the legs up a bit
[DOUBLEPOST=1461902102][/DOUBLEPOST]Problem solved :D
Ill add more washer under the servo legs and it should be good
Sure is cant wait to order those braces also from greg
And thanx to your post about kraton upgrade
Thats where i got the idea of using that servo :D
Problem with my servo
The servo holder and servo are so close to the driveshaft
I grind the servo holder a bit
Then my problem was the servo wires again lol
Touches the driveshaft
Soni did this to my wires
Looks good
Sup guys
Im about ready to run this talion for the very first time lol
Im still in need of a single 4s lipo battery
Servo is already in place but not the servo horn since i still need to calibrate my esc and centered that servo
But before i can do any of that i will need a lipo battery to power up the esc
Im about to order this lipo battery right now unless someone can suggest a better battery or give me a link of that battery
SPC 6500mAh, 65C, 4S
Traxxas Rustler LCG rx box
Upgrade that rx box with this
Youll have more room for wires etc.
Now this thing have a holes for the screw but not the same with the arrma
So you have to make your own holes for it and use the same screw that came with the arrma :D
Awwrite this talion still haven't seen dirt
Its up for sale needs the funds for something else
What you see here is what you get
Minus the remote and the servo(accidentaly cut the darn wires lol)
350+shipping
Interested? Pm me
Ok sonce nobody seem to want this talion
Im going to continue with upgardes lol
Ordered this tires for it and among other things from tower hobbies
Waiting for gka set for this build
