Get ready for 70+ MPH speeds right out of the box with the new Arrma Talion V3. The ultra-sleek, low center gravity Talion 6S BLX features a redesigned front end that is lower, sleeker and dramatically reduces drag while boosting top-end speeds.
The V3 Talion suspension has also been optimized for on-road speed run, yet it is equally at home going off-road. The electronics have been moved closed to the back of the vehicle for better stability!
Arrma Talion Features:
- Aggressively designed low-profile body
- Low-profile dBoots Katar tires designed for ultimate bite
- Newly designed multi-element high-downforce wing
- New tire and wheel package is optimized for on-road speed runs as well as off-roading
- Lower shock towers allow low and sleek body shell for superior aerodynamics
- All-new shocks with 4 mm shafts, aluminum top caps, adjusters and bottom caps complement the shock towers and boost durability
- New, larger radio box
- New low-profile wing mount
- Stronger front hubs
- Stiffer servo mount
- Stronger bulkheads
- Stronger front and rear chassis braces
