Jadefalkon
New Member
Looks pretty close, but maybe a bit loose. Did you do the paper trick, or by feel?
As a test, when the motor/diff is still out of the car, I will power up and run the motor at low speeds. You can hear too tight. Too loose, you won't hear, but you can feel by rocking the spur. there should be some play when you rock the spur, but not much, maybe a 1/64th?
