Eh. 120c is a BS lie imo. 5000 mah is lighter and easier on your rig than the latter choice. Especially the light, 3s platform with the lighter duty pinion, spur gear, diff and diff bearings. I went with higher mah for my 6s Senton/typhon cuz I got cheap batteries to make up for the fact that the mah capacity on those are a lie as well as the C rating discharge capacity. I wouldn't go any heavier or larger than 5200mah for your 3s rig...fwiw.i don't know the difference. i have an arrma senton 3s blx and i don't know if i should get the spectrum battery wich is a 5000mah 50c 11.1v batter or the other one wich is a 6800 mah 120c 11.1v battery
will the 6800 mah fit in the battery tray the more mah the bigger they are normallyi don't know the difference. i have an arrma senton 3s blx and i don't know if i should get the spectrum battery wich is a 5000mah 50c 11.1v batter or the other one wich is a 6800 mah 120c 11.1v battery
I have the same truck and a 3s typhon also. Some bats as high as 7200mahi don't know the difference. i have an arrma senton 3s blx and i don't know if i should get the spectrum battery wich is a 5000mah 50c 11.1v batter or the other one wich is a 6800 mah 120c 11.1v battery
Neither. Stay away from the Spektrum Smart batteries and the Amazon cheapos.
